From behind the IP gear cover:
6.9D U2 U5(?) 25407_ (I think the _ is a 1, but half is covered by the valley pan seal). On the emission sticker, may/june is punched out. Is that even the right place to get the block number?
Here is a list originally posted by Pete, PLC7.3 that gives the best run down I ever saw.
And looking at the list, you block is fine.
6.9 blocks up to serial #u2u17900 had a thinner casting around the block heater. It is very common for these blocks to crack.
6.9L Old Style Block
Block Casting Number:
On left side of block (beneath oil cooler) 1805440C1
Note: Some 440 blocks are truly new style and must be visually inspected by raised donut around the block heater, frost plug (right rear). Old style below serial number 173828.
Visual Identification: *No counter bored area for block heater
*No defined area on side of block for dip stick
*Thickness of cast iron around block heater 3/8" (.375")
Head Bolts: *7/16, 12 point socket is used to torque head bolts
*Block tapped with 7/16-14 for head bolts
6.9L New Style Block
Block Casting Number: 1807996C1 Note: Some new style blocks have casting
number 440. Above serial number 173828.
Visual Identification: *Has counterbored area for block heater
*Very defined relief area cast in side of block for dip stick tube.
*Thickness of cast iron around block heater 15/32" (.470")
*Latest style (not all new style 6.9) has ribs around head bolts, rear two on left side go from head gasket surface to pan rail - same as 7.3
Head Bolts: *Same as old style 6.9
Good, cause its sure nice to have that sucker plugged in in the cold weather...even though were not even close to that yet (40s and 50s all week).....this winter blows, WHERE'S ALL THE SNOW!!!
Just talked to a friend in fairbanks 38 below last night and supposed to get colder and stay for 7 to 10 days them people dont want to talk about global warming.
Just joined (and posted a welcome post!) and I have a question about this topic. 1807996C1 is mentioned as a good block; however, my number is "1805011C2". Is this the new style block or not? I could assume C2 followed the C1 series, but I would rather know for sure. Any help would be greatly appreciated.
More importantly, check the block s/n stamped next to the IP gear cover on the driver side. Refer to the chart on post #52 in the tech thread...
