9" Rear Diff.
Old Dec 25, 2008 | 08:39 PM
rwlacks's Avatar
rwlacks
9" Rear Diff.
Just built new 9" rear diff. new Traclok and 3.50's all new bearings ect. Question is I have a leak between 3rd member and case used a gasket but was told by buddy not to use it. The factory did is this not correct ?? also i forgot to mention the copper washers do i get new ones or will a small amout of silicone not work ???
Old Dec 25, 2008 | 10:34 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Gasket with silicone plus you need the washers.
Josh
Old Dec 26, 2008 | 01:02 AM
monsterbaby's Avatar
monsterbaby
I haven't used a gasket on a 9" in 30yrs and only had one leak. blue or black rtv only. I have run them with and without the copper washers but will say the only time I had the leak I wasn't running them but many times I have done it and they didn't leak either. But with that said I believe I would get new ones especially if you don't plan on taking it apart very often.
Old Dec 26, 2008 | 05:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Every 9" from 1957 thru 1986 came from the factory with the carrier gasket and copper washers.
E3TZ4035B (replaced B7A-4035-A) .. Carrier Gasket
10) 373820S .. Copper Washer / Use w/3/8" stud / 13/32" I.D. / 19/32" O.D. / 3/64" thick.
The washers are still available from Ford, but no dealer in AL stocks them. If you special order them, you'll prolly have to buy the entire package of 40.
Ford parts vendor Green Sales Co. in Cincinnati OH has 320 of them: 800-543-4959.
Old Dec 27, 2008 | 06:52 PM
Alvin in AZ's Avatar
Alvin in AZ
Get copper washers from the hardware store.
The ones I used were in the plumbing section.
They appeared to be "flare fitting washers". {shrug}
Every 9" I've rebuilt got no gasket and didn't leak except where I bent the
axle housing getting the stuck sucker out. ;) Had to take it out again anyway
so it was no sweat but with the housing straightened out, no leaks (at all)
the second go around.
Did you pry on the housing where it's leaking?
Gaskets are a pain. YMMV
Ultra Black was made especially for me and my hatred of everything gasket. ;)
Carburetor gaskets (on the other hand) get a generous dousing of silicone
spray or silicone grease.
Alvin in AZ
bearster18
Jul 18, 2012 03:47 PM
92nite351
1997 - 2003 F150
Aug 6, 2011 09:23 PM
rtazz17
41
Jul 1, 2011 04:20 AM
pdqford
Jun 16, 2008 09:37 PM
khadma
Oct 30, 2007 12:56 AM
