Rear Diff Cover Removal
Old Jun 16, 2008 | 12:07 PM
pdqford's Avatar
pdqford
I see a leak in the rear diff cover mating surface on my (new to me) 2002 Navi (w/9.75" rear end).
Is there gonna be enough room to remove the rear diff cover without having to drop the panhard bar and/or the rear sway bar?
Thanks guys . . .
Old Jun 16, 2008 | 08:16 PM
pdqford's Avatar
pdqford
Cancell that last question - the cover j-u-s-t fits between the panhard bar and the swaybar with the frame jacked up and the axle drooping.
Nudder question - should the cover bolts be installed dry or do they need a sealer? And when I took the bolts out there appeared to be the remenants of somekind of an RTV like little washer under the head of each bolt. Are these special washers or did some one carefully put a bead of RTV under the head of each bolt? And is it necessary?
Old Jun 16, 2008 | 09:13 PM
Gage2502's Avatar
Gage2502
When I did my Diffs I didnt use any kind of sealer on the bolts, I cleaned them and installed them dry. Also now would be a great time to paint the cover.
~Gage~
Old Jun 16, 2008 | 09:21 PM
pdqford's Avatar
pdqford
Thanks for the info Gage2502.
I got more time in cleaning, wire brushing, grinding, sanding, priming and painting that diff cover than I have in any other part of this project!
Old Jun 16, 2008 | 09:37 PM
sbclemens's Avatar
sbclemens
Check the flatness of the cover before reinstalling it. I put a thin bead of rtv on my cover just to be safe. I also painted the cover but should have had it powder coated.
robert_l_ross
May 14, 2015 03:28 PM
texasJ
2004 - 2008 F150
Sep 3, 2014 06:19 AM
slowmans
Ford Truck Parts for Sale
Mar 31, 2014 06:35 PM
mschultz
Dec 14, 2009 05:03 PM
Peter Richards
Jun 16, 2007 09:50 PM
