Intermittent check engine light
Old Dec 25, 2008 | 09:48 PM
wrdabney's Avatar
wrdabney
thanks for all of your help. im about 5 1/2 hours from atlanta so maybe i will stay up and try to fix it. I really appreciate all of the insight
Old Dec 25, 2008 | 09:53 PM
F350-6's Avatar
F350-6
I don't know how late I'll be up, but if you have more questions and no one else is responding, try asking down the the 99 - 03 7.3 diesel section for any questions you may have along the way. It's further down the main forum listing, or here's a link to it https://www.ford-trucks.com/forums/forum31/
Old Dec 26, 2008 | 10:10 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 7.3 forum
Old Dec 28, 2008 | 09:17 PM
wrdabney's Avatar
wrdabney
well i ended up not working on the truck that night and just took it to ford friday morning to get the codes read. They said that the transmission solenoid pack was bad so I took it to the transmission shop who rebuilt the tranny about 5k miles ago. It is under warranty so they are supposed to fix that for free. Anyway, here are the codes that they gave me. They said to fix the tranny solenoid pack first then go from there.
O/D
P0743
P1275
P1277
Engine
P0470
P0472
P0478
P0741
P0743
P1316
Do these engine codes seem to be the symptoms of the UCVH being loose?
Old Dec 29, 2008 | 06:19 AM
F350-6's Avatar
F350-6
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
P0472 Exhaust Back Pressure Sensor Circuit Low Input
P0478 Exhaust Pressure Control Valve High Input
P0741 TCC Circuit Performance
P0743 Torque Converter Clutch System Electrical Failure
P1275 High to Low Side Open — Cylinder 5
P1277 High to Low Side Open — Cylinder 7
P1316 Injector Circuit/IDM Codes Detected
Yes the codes support an injector wiring (connector) issue. For the EBP codes you can try this Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Aug 26, 2012 | 01:23 PM
Bri Buck's Avatar
Bri Buck
same kind of check engine light problem
so when my truck starts, i have a check engine light on. it runs rough, cant get up to speed and wastes lots of gas. however if i let it warm up for bout half an hour or so the engine does this rev by itself and then the check engine light goes off and it runs fine. im not sure if these fixes are the problem or if its something else. i was thinking of replacing the o2 sensor... is that the prob? also when its runnning crappy like that there is black puffs coming out of the exaust but not when its running good. im super confused on this issue because i have done the basics, new oil, spark plugs, and replaced cracked manifold.
HELP!!!
Old Aug 26, 2012 | 01:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The check engine light means a code has been stored that will tell you where to start. Without the code all you can do is start buying parts hoping you get lucky.
Old Aug 26, 2012 | 02:00 PM
BigAlsPSD's Avatar
BigAlsPSD
HELP!!!
What engine do you have? Being that you mentioned spark plugs, what ever those are, lol. I'll venture that you have a gasser, the forum you posted in is the 7.3 powerstroke super duty forum.
But to help, read the codes, it will help point you in a direction. If a modular motor like the 5.4 or 6.8 and you are getting a misfire detected, I would look into the COP.
Old Aug 26, 2012 | 03:08 PM
Mark Kovalsky
How do you know that he is getting a misfire detected? It doesn't say that anywhere. The CEL on does not mean misfire UNLESS the CEL was flashing.
Old Aug 26, 2012 | 04:03 PM
BigAlsPSD's Avatar
BigAlsPSD
I don't nor did I mean for it to sound like he was, I was just saying that IF he had a modular motor AND it was getting a misfire detection that's where I would lean. Just offering suggestions instead of simply saying "out of my forum".
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
cgeer33
Jul 29, 2017 06:49 AM
smileyp
Escape & Escape Hybrid
Nov 5, 2016 11:44 AM
steuspeed
Jul 29, 2016 04:12 PM
ztuck
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 4, 2006 11:07 AM
