I just called 2 of my local companies that balace or check drive shafts. One qouted me 45 for each with a price break? since there is 2 shafts (Fleetpride) the other wamts 140 for doing it (Republic Desiel)
What has everyone else paid to have this service done?
I paid around $260 IIRC to have my rear balanced and new u-joints installed, can't really comment on a balance alone. $45 seems pretty reasonable though
I paid about 150 for mine, but they also picked it up and returned it to local mechanic for me so I didn't have to take it to them. Make sure you take both pieces .....they have to be balanced as an assembly.
I paid $175 to get it completely rebuilt with new slicer joints and balancing.
Seth, did you use Action Machine in South Bend,IN. I have used them in the past and I know they are a Spicer dealer too. When I get around to doing my ujoints that is who I am thinking of using.
And a local driveshaft shop told me $65 to balance both shafts.
Ok I think I have found my issue after 1 year! The drive shaft has all new U-joints and greased the slip point new carrier bearing. I have read where some one mentioned to shim your carrier bearing down for les of a angle. Today I decieded to do this. Which consisted of 2 washers thick across. As you can see from the Pic. What I experianced from removing the mounting bolts that hold the actual bracket that spaces the carrier bearing down moved. Which i see that the spaceing bracket is held to the frame is attached by Rivets. With This movement that I saw it explains my periadict vibration. Has anyone found this before? I figure i would grind down and drill the rivets out and remount the spaceing bracket with High grade one size larger nuts and bolts. As I asked before has anyone else found this before? If so what was your repair?
