Bronco II Ford Bronco II
auto tranny fluid level
Old Dec 23, 2008 | 02:24 PM
sdort's Avatar
sdort
So this '88 B2 I just picked up is an auto - my other one is a 5-speed. I assume this is an A4LD? Is it possible to check the fluid level when it's cold and not running? If so, where should it be on the dipstick? Thanks!
Merry Xmas
Old Dec 24, 2008 | 10:10 AM
tommyleea's Avatar
tommyleea
Merry Xmas
It is possible, but not accurate. It will be quite a bit over the full mark when you check it cold-not running, but that alone doesn't mean the level is correct, because there is no cold level. Need to check it warmed up, run thru the gears, and then check. Cheers and Merry Christmas to all!
mikey v
2009 - 2014 F150
23
Mar 7, 2012 04:33 PM
sigtauenus
Apr 2, 2010 11:30 AM
state
Sep 8, 2003 01:16 PM
state
Sep 8, 2003 11:50 AM
shimonmor
Apr 13, 2000 11:48 AM
