how long should it be plugged in?
Old Dec 23, 2008 | 02:25 AM
Jknapp79's Avatar
Jknapp79
ok i know the thread is here somewhere about how long a truck should be plugged in for, but i cant find it. i have used the search, all i seem to come up with though is people looking for where the plugin is.. anyways if someone knows where its at i would appreciate it!
Thanks
Josh
Old Dec 23, 2008 | 02:42 AM
hanklin's Avatar
hanklin
plug in for as long as you like. Generally run an outdoor timer and set it for 3 hours before start-up.Turn on defrost dial and heat setting that way it`ll keep windshield clear.The cord it self is usualy behind the drivers side fog liight area,capped off
Hanklin
Old Dec 23, 2008 | 02:47 AM
hanklin's Avatar
hanklin
BTW
I ran an extension cord (1 ft) from mine out tofront of bumper so I can get to it easier
Hanklin
twags6's Avatar
twags6
3 hours is a good amount and a nice heavy duty timer can do that for you. If you dont mind the higher electric bill, plug in whenever you can, it wont hurt. I do that at work all the time
Welcome to FTE
Old Dec 23, 2008 | 08:08 PM
Jknapp79's Avatar
Jknapp79
i changed the cord out already, it was bad. luckily the oreillys had a heater,with the new cord so i just changed the cord.. ran it out through a hole in the grille. so its easy to get to. just need to find a cover for the end of the plugin now. also gonna have to get a timer for it. dont need that much higher of light bill.
Old Dec 23, 2008 | 09:07 PM
strickracing's Avatar
strickracing
I leave mine plugged in all the time but the shortest on a cold day would be like 2 hours before u start
Old Dec 23, 2008 | 09:37 PM
Izzy351's Avatar
Izzy351
Even an hour to an hour and a half will make a difference. I plugged mine in the last two mornings for about that long, and it's MUCH quieter than if I don't. But then again, it's "only" been in the 20s in the mornings, and I park it in my garage.
Old Dec 23, 2008 | 10:27 PM
beanhead6D5's Avatar
beanhead6D5
3 to 4 hrs. is enough.Get a 15amp x-mas light timmer,they work good have used my timmer for two years now.
Old Dec 23, 2008 | 10:53 PM
Tenn01PSD350's Avatar
Tenn01PSD350
When I go hunting, I get up, get my coffee, go out and plug the truck in, then watch news scratch rear and get ready. It has been as short as 1/2 hour and still made a diff in the 20s. I guess my point is, if money is tight, get up a bit early on cold days and plug it up. Experiment with it and you will find what makes you happy. Low 20s and teens need about an hour for me. I have only left my truck plugged in overnite for a couple of times. That cold, I leave it parked unless I have to go.
Old Dec 24, 2008 | 05:46 AM
Fraalan's Avatar
Fraalan
does ne1 know the actual amp draw.
great idea on the timer.
Old Dec 24, 2008 | 08:00 AM
DieselCamper01's Avatar
DieselCamper01
I do not know the amp draaw but I use the 15amp xmas light timer also with no problems for the last two winters. Set for 3 hours.
Old Dec 24, 2008 | 08:46 AM
beanhead6D5
It's 8 or 9amps.
Old Dec 24, 2008 | 08:53 AM
sflem849's Avatar
sflem849
I did a search of the whole internet and FTE two years ago and the most constructive stuff I found was plug it in one hour for every ten degrees below freezing
I have found this to be VERY accurate. Then again, I run mine on a timer when I have a use schedule (read - going to work everyday at 7:00) and the timer comes on at 4:30. This is plenty fine all of the days, on the really cold ones you just don't get heat instantly.
Old Dec 24, 2008 | 09:35 AM
preppypyro's Avatar
preppypyro
Up here lately it has been just shy of minus 40 degrees celcius, with the windchill around 50. Ive been finding that my truck needs to be plugged in 4-5 hours when it gets this cold out.
She turns over very slowly when I leave it in for 3 then try it, but I am running dino oil in the engine right now too. Synthetic would make a huge difference.
