need help
Old Dec 22, 2008 | 09:36 PM
allen o's Avatar
allen o
need help
ok guys, been a while since i tore it apart & now going back together with it. the valve cover has the oil filler hole in the front(threaded), and the pcv hole in the rear. don't remember if the oil filer had a connection to the air breather. what about the middle one? Is this where the crankcase inlet goes? I'm not rebuilding stock. searching for a crankcase breather for the middle but can't find one with a small size to fit. seems like all the aftermarket are for a 1 1/4" hole. any suggestions?
Old Jan 12, 2009 | 09:56 PM
rijrnnr's Avatar
rijrnnr
The middle hole is supposed to connect to the cold air inlet pipe...the big pipe that goes between the air filter and the throttle body. Don't ask me what it is for, because I don't know. I'm assuming you've got fuel injection.
Old Jan 12, 2009 | 10:55 PM
Harte3's Avatar
Harte3
Check with the speed shops in your area...they may have a grommet/adapter kit for the valve cover holes specifically for Ford applications.
Old Jan 12, 2009 | 11:15 PM
allen o's Avatar
allen o
got it!! found a edlebrock breather to go there..oil cap in front breather and then the PCV valve in the rear......spun the engine, got good oil pressure, waiting on the carb and distributer to finish the rebuild
OFF 59
13
May 31, 2012 10:22 AM
dwrestle
Nov 18, 2011 12:20 AM
Ryan85
Jun 12, 2011 02:07 PM
hooler1
Apr 16, 2011 11:00 PM
dreamd0g
Apr 21, 2007 08:14 PM
