Ball Joints
Old Feb 2, 2009 | 10:44 AM
afonda's Avatar
afonda
What is the test for determining if your ball joints are good or bad?
Old Feb 2, 2009 | 10:57 AM
mueckster's Avatar
mueckster
Raise the front wheels off the ground about 1" and put a bar under the tire. You shouldn't feel any play in the wheel when trying to raise it. Check for slack in the hub bearings by grabbing the wheel, with your hands, at the 'top and bottom'. 'Front and back' to check to tie rod slack.
Old Feb 2, 2009 | 03:07 PM
Orezona's Avatar
Orezona
Originally Posted by ottomatic
moog is much better thamn the fords last ones were ford. Only got 120,000 mi out of em.
Put moogs in my 86 6,9 had over 250,00 on em . Sumof a bitch that stole the truck is probably still driving on em
orezonea: Do you have their phone # ???
1-800-234-3455
Old Feb 2, 2009 | 03:36 PM
Cracker 73's Avatar
Cracker 73
upper ball joint napa 260-1248 and lower 260-1395 48.49 u and 73.49 L these are not moog they are napa chassis with grease fittings they are better per NAPA hope this helps i have in my truck got 175 k on ford non grease fitting !
Old Feb 2, 2009 | 07:42 PM
OTTOMATIC's Avatar
OTTOMATIC
My OEM's went at 184,000. 2nd set from Ford started going at 300,000
Orenzona.... THANKS
I am shooting for 1,000,000 mi on this truck. Still have original u-joints, injectors, glow plugs & relay, Valve covers have never been off.
Replaced water pump once , passenger side hub unit 2x , just relaced alll other front end parts. So over 300,000 on OEM tie rods track bar etc,
Wish me luck on the Million mi.
Old Feb 3, 2009 | 06:53 PM
StanleyZ's Avatar
StanleyZ
Anyone wanting to do ball joints, there is a great thread on the heavy duty/super duty forum. I can't remember the writer's handle but this thing is step by step with great pictures. Even I could do them with that cheat sheet.
Old Feb 3, 2009 | 09:04 PM
afonda's Avatar
afonda
Just checked mine...
Both tires felt solid with no movement up, down, side to side. Also checked the pitman arm, steering linkage, and such and all was tight with no play.
I'm guessing that I am going to have to check the steering box. It may need to be adjusted. And I need to change out my bushing on the sway bar link arms.
Old Feb 3, 2009 | 10:23 PM
OTTOMATIC's Avatar
OTTOMATIC
I usally use the camber or how far the tires are leaning in. Both times It was hard to tell if ball joints were bad even with truck jacked up and prying with crowbar. The only indication was trucks wandering got worse along with tires leaning in or camber way out. also ocasionaly steering locked slightly when turning . I had my suspicions and tire place confirmed them
Old Feb 4, 2009 | 05:28 PM
john_from_ict's Avatar
john_from_ict
Anyone else use the NAPA ball joints? I am trying to decide between them and the Moog's.
Old Feb 4, 2009 | 07:30 PM
OTTOMATIC's Avatar
OTTOMATIC
I just ordered the kit from Powerstrokes today . I personaly like the Moogs. I 've had better luck with Moog for steering parts,
Federal-Mogul - Moog Ball Joints
SKaero
Aerostar
Sep 13, 2016 07:12 AM
granny_rocket
Mar 31, 2016 01:33 PM
Coachhick
Feb 17, 2016 10:52 AM
WhatsAChevy?
19
Dec 7, 2015 02:17 PM
boosteddsm
Jun 15, 2011 09:44 PM
