1978 - 1996 Big Bronco
Best Gear Ratio?
Old Dec 21, 2008 | 06:25 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Best Gear Ratio?
im wondering what would be the best gear ratio for a dana 60 rear and front trac-loc(posi). it would go on a 1978 bronco with a 460 that will be in the mud 70% and road 30%. dont rock crawl just muddon and trail busting.
Old Dec 21, 2008 | 07:12 PM
NWBronco's Avatar
NWBronco
You failed to mention the most importnat factor, tire size. The larger the tire diameter, the lower gear you'll need. Transmission is the #2 aspect. Autos tend to need lower gears where manuals can compensate a bit more.
Old Dec 21, 2008 | 09:56 PM
YoungFordAddict66
I'll be putting 35's CO-OP Grip Spurs on, they are 9X35X16 and i havent decided wether to put in an auto or manual, but im planning on putting a 4 speed manual in.
Old Dec 22, 2008 | 09:04 AM
wileec's Avatar
wileec
Having trouble making up your mind?
With 35s I would look to 4.45 maybe 5.13 but that might be a bit low for mud we do not get much of that around CO.
Old Dec 26, 2008 | 07:42 PM
WhëëlMå1's Avatar
WhëëlMå1
With 35"s and real offroad driving, Id say 4.56 to 4.88.... will make the truck wicked
Old Dec 28, 2008 | 03:08 PM
helirich's Avatar
helirich
What Wheelman said!
Old Dec 29, 2008 | 04:06 AM
roger dowty's Avatar
roger dowty
i might agree with above i think but would also need to know torque curve of the engine...thats a big deal. An engine like my 400 with 400ft lbs at 2krpm...and its an engine that i would not want over 4k very often and never over 5k. So 4.11 might be a better bet... could be similar with your 460 depending on if it's upgraded or an older 460 that wasn't neutered in '72 and after.
theres a site linked somewhere... probably in the off road thread that will give you charts for tire size etc...final gear is whats important. I'd also look at my experience what I like and compare prev rigs to the chart for a comparison. Most serious folks know from experience what they want.
For me the ultimate would be a t18-19 tranny, gearmaster under/overdirve going to a 205 transfer case and 4.11 range gears with 33" tires. You have 8 forward gears with all the ow end I need plus a final drive that would have me at 2400rpm @ about 70-75 mph or 2k @ 60-65 for great mileage.
Old Dec 31, 2008 | 08:31 PM
Trevor1's Avatar
Trevor1
4.10 gears are perfect in my 79 bronco with a 460 c6 automatic and 38 inch boggers. throws mud 20 ft. in the air with ease and smokes the tires easy too
lonewolf777
1983 - 2012 Ranger & B-Series
Jan 28, 2011 09:11 PM
Windsor84
Jun 11, 2006 12:29 AM
ustolemycupcake
28
Mar 21, 2005 10:11 AM
ford78460
Jan 27, 2005 02:00 PM
Billy121181
May 13, 2003 02:54 PM
