Aftermarket Tachometer Hookup Question
Old Dec 21, 2008 | 02:08 PM
burninrubber2416's Avatar
burninrubber2416
For christmas I got a aftermarket tach from my dad. I got the power, ground and illumination wires all hooked up. I know your supposed to hook it up to the negative part of your coil, question is, where is it at on a 1987 F150 with a 4.9L I6? Lol. I looked through wiring diagrams and looked it up on the All Data DIY program, but I couldnt find any negative/ground for the coil. So where can I put the green wire at to get it to read RPMs? Whereabout under the hood, and what color(s) should the wire be? I did a search for the topic, but came up with no answers to where it would be. I seen someone say something about a Tach Testing wire or something of the such. Any help would be appreciated. Thanks guys.
Old Dec 21, 2008 | 03:32 PM
DJdemon6696's Avatar
DJdemon6696
isnt it the positive from the coil?? nway its on the coil.. on the passenger side of the engine of the 4.9 chek wich one works.. there are 2 wires goes to the coil.. connect it tot he red if it doesnt work connect it to the other one it wont damage the tach atleast it didnt damage mine.
Old Dec 21, 2008 | 05:25 PM
JB88BII's Avatar
JB88BII
You connect the signal wire from the tach to the GREEN wire on your ignition coil, which is the negative side djdenon is right there are only two wires going to the coil but the green one is the one you need to get the signal from.
Old Dec 21, 2008 | 05:51 PM
burninrubber2416
Thanks guys, I hooked it to the green wire and all went well. Appreciate the help.
Old Dec 21, 2008 | 05:56 PM
pc_2000's Avatar
pc_2000
Which tach did you get? I'm planning on getting myself one for Christmas as well. I'm thinking just a small one to mount on the column offset to the left a little.
Old Dec 22, 2008 | 06:48 PM
burninrubber2416
Its a Sunpro tach its all I know. Its rpm range goes to 8000 rpm. It has a white face, and can select between 4, 6, or 8 cylinders. Nice tach I like it alot.
Old Dec 22, 2008 | 09:49 PM
pfogle's Avatar
pfogle
Is it the small one or the large one? I had the small one in a '92 E150 with 351w and I loved it. It was nice watching it jump to 4300rpm when you stood on it. I like the factory tach in my olds. Stand on it at 60mph and watch the tach hit 6k before it shifts. Then the damned thing is governed at 110mph so it never even shifts out of third gear before the computer shuts it down. I believe that car would run 160mph if you removed the software governor.
Old Dec 23, 2008 | 06:33 AM
pc_2000's Avatar
pc_2000
Thanks, that just so happens to be the one I was looking at in the Zone for $29.99. I think I'm going with the black face sine my truck does already.
JayzDaddy
Feb 4, 2015 09:02 PM
Dkrowland81
Dec 28, 2010 08:51 AM
IcemanV8
Nov 5, 2007 06:30 AM
Dads 66
Jan 1, 2005 06:46 AM
