tranny going out
Old Dec 21, 2008 | 02:21 AM
joe f350's Avatar
joe f350
tranny going out
i had it rebuilt about 1500 on the rebuilt it a t19 in the moring it dosent want to shift it has fluid when i check it can gusting out could it be over packed with fluid for could the place have done a botched job of got a bad part i can feal the clutch sliping and it changed at the same time some time when i push in the clutch and go to shift some times a hear a gringing noise and then i press the clutch and them shift it a sysro is out
Old Dec 21, 2008 | 05:03 AM
PLC7.3's Avatar
PLC7.3
What oil did they use in the trans........ the T19 manual states
SAE 50 engine oil above.... 0*F
SAE 30 engine oil below.... 0*F
If they used 90 wt gear oil that would cause some problems with shifting....
Old Dec 21, 2008 | 06:40 AM
fonefiddy's Avatar
fonefiddy
Dude, You really need to take some time, and FORM SENTENCES, USE PUNCTUATION.
Old Dec 21, 2008 | 07:38 AM
Lazy K's Avatar
Lazy K
Sounds like you need to check your clutch operating mechanism.
Check the fluid level. Check for fluid leaks. Check the firewall for flexing around the master cylinder and check the pedal mounting.
Old Dec 21, 2008 | 08:25 AM
smokey98's Avatar
smokey98
Dude, why so bitter?
Old Dec 21, 2008 | 09:57 AM
rmalottwtes30's Avatar
rmalottwtes30
Because its hard to read and understand...
Old Dec 21, 2008 | 10:34 AM
smokey98's Avatar
smokey98
Yeah, I was just checkin with fonefiddy. It seemed like he was a little put out in another thread too.
Its all good!
Old Dec 21, 2008 | 02:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
All I am going to say is this, the harder a post is to read, the less help a person is likely to get.
If you can't figure out what is being asked, it is very hard to answer with correct information.
Old Dec 21, 2008 | 03:46 PM
joe f350's Avatar
joe f350
davemy trany isnt wantin to shift and to gear and when i press the clutch to shift it stars grinding gears i was asking if the shop could have used bad part of done a half *** job of could the tranny be over pack with fluid
Old Dec 21, 2008 | 03:47 PM
joe f350's Avatar
joe f350
the fluid was green with black specks
Old Dec 21, 2008 | 08:02 PM
Dave Sponaugle
The first thing I would check is clutch master cylinder fluid level.
Check #2 have someone push the clutch in while you watch the clutch master cylinder.
If you see movement, the fire wall is cracked.
Fire walls are known to crack, the master cylinder moves enough that the clutch does not engage far enough for smooth shifts.
As it gets worse, you will not be able to get it in and out of gear at all.
PS you should check this before you kill the new tranny.
If the firewall is cracked, it's not actually the tranny at fault.
Old Dec 21, 2008 | 08:05 PM
joe f350's Avatar
joe f350
how do i fix it weild the fire wall at the crack
Old Dec 21, 2008 | 08:16 PM
RCrawler's Avatar
RCrawler
There is a repair kit available through Ford to repair the firewall. I figured they would have all been fixed by now...
Jason
Old Dec 21, 2008 | 08:57 PM
joe f350's Avatar
joe f350
the fire wall isnt craked what next
Old Dec 21, 2008 | 09:01 PM
lovemylariat2007's Avatar
lovemylariat2007
do your homework on a shop before you take it there sounds like a half assed job to me
