tranny going out
Old Dec 22, 2008 | 03:42 PM
  #31
fonefiddy's Avatar
fonefiddy
Originally Posted by starmilt
fonefiddy in your signature you mention velvet ride can you tell me something about this and how you like it. Plus what is a turbo bumper thanks.
Velvet Ride Spring Shackles are torsion spring loaded shackles. They make the truck ride a little softer when Your unloaded.
The Turbo Bumper is the OBS bumper with the holes in it. They started on IDI Turbo's, and Eddie Bauer Editions, in '94. Seems like there were more trucks built with them later in the production of the OBS. The bumper allows more air, direct access to the radiator. My coolant would get pretty hot on long uphill climbs. 12 psi seems to raise coolant temps pretty good
So I hunted one down, and it seems to help. The fan clutch doesn't need to kick in as soon, with the holy bumper.
If You look closely at My sig pic, you'll see the holy bumper.
Old Dec 22, 2008 | 04:01 PM
  #32
starmilt's Avatar
starmilt
Thanks My old 86 rides pretty good actually but seems like the older I get the better ride I want and I am unloaded way more than loaded.
I can definately see the concept on the bumper too.
Old Dec 22, 2008 | 06:56 PM
  #33
joe f350's Avatar
joe f350
my ride like a tank my friend call it the tiger after the tanks its that bad
Old Dec 22, 2008 | 07:19 PM
  #34
ke5adb's Avatar
ke5adb
my zf tranny does that when its cold too. I know the synchro for 2nd is bad, but i just double-clutch 2nd and it doesn't grind. dunno if the zf is supposed to have a synchronized 1st gear. if so, the synchro is out on it too. also pops out of reverse quite a bit.
Old Dec 22, 2008 | 07:24 PM
  #35
starmilt's Avatar
starmilt
Common on the zf you gonna get to use some of the money you saved on the tranny pretty quick.
Old Dec 22, 2008 | 07:26 PM
  #36
ke5adb's Avatar
ke5adb
it was in the truck when i bought it. just waiting on the tranny to go boom so i can put the original 4 speed back in it. maybe i'll drop a 6bt cummins with a 6 speed, or an 8.3 cummins with a 9 or 10 speed in it.
Old Dec 22, 2008 | 07:33 PM
  #37
joe f350's Avatar
joe f350
8.3 that aint going to fit but wold be cool
Old Dec 22, 2008 | 09:02 PM
  #38
ke5adb's Avatar
ke5adb
anything will fit with a cutting torch and a welder. saw a 3208 Cat motor hooked up to the E4OD tranny in a 92 f350. fenders and cowl were stretched, F550 axles under it. It could be done. All it takes is time and some physics.
Old Dec 22, 2008 | 09:29 PM
  #39
starmilt's Avatar
starmilt
you forgot money the big factor.
Old Dec 22, 2008 | 09:33 PM
  #40
ke5adb's Avatar
ke5adb
shhhhh, what the little woman don't know, won't hurt her.
Old Dec 22, 2008 | 09:38 PM
  #41
starmilt's Avatar
starmilt
Are you sure garcia means thank you.
Old Dec 22, 2008 | 09:41 PM
  #42
ke5adb's Avatar
ke5adb
Thats what I've always said. I failed my mexican class back in high school, but all the mexicans i ever worked with knew what i was saying. lol
Old Dec 22, 2008 | 09:55 PM
  #43
starmilt's Avatar
starmilt
I think that is a couple of DOT's name gracias is thank you.
Old Dec 22, 2008 | 10:40 PM
  #44
joe f350's Avatar
joe f350
u guy are to funny
Old Dec 22, 2008 | 10:52 PM
  #45
starmilt's Avatar
starmilt
I'm serious.
