tranny going out
Old Dec 21, 2008 | 09:17 PM
joe f350's Avatar
joe f350
i did they have been there for 30 year my mom has been going to this shop for years
Old Dec 21, 2008 | 09:26 PM
starmilt's Avatar
starmilt
Joe get under the truck watch your clutch lever make sure it is moving enough.
While your under there make sure your trans doesn't move back it doesn't take much I have seen this happen several times with a cracked bellhousing.
If your not getting enough clutch movement time to look under the dash the holi in the rod going to the mastercylinder sometimes wears again it doesnt take much.
I have even had to replace the pedal assembly before because of too much wear does your pedal have much slack in it.
Old Dec 21, 2008 | 09:35 PM
joe f350's Avatar
joe f350
look under the dash the clutch lever is bran spanking newer not much slack but the cheack pont is towers the end i hav e a zf5 bell houseing and a zf5 how hard would be just to swap them and would my tcase match up to the zf5 and would the zf5 hold up to my tires and lift
Old Dec 21, 2008 | 09:48 PM
starmilt's Avatar
starmilt
If the zf5 was a 4x trans it would work not sure about the 2x4 trans though weather it would hold up depends on you. It still sounds like a clutch problem to me.
Old Dec 22, 2008 | 12:04 AM
joe f350's Avatar
joe f350
pedale is it lose need to be titen replaced
Old Dec 22, 2008 | 12:10 AM
starmilt's Avatar
starmilt
You need to figure out where it is worn it doesn't take much wear anywhere and it is usually 2 or 3 places compounded together.
Old Dec 22, 2008 | 12:13 AM
joe f350's Avatar
joe f350
the petal still works iam about to do what i do best hit it with a big fuking hammer
Old Dec 22, 2008 | 12:37 AM
starmilt's Avatar
starmilt
I need your phone # so I can call your mom and tell her to lock up the hammers.lol
Old Dec 22, 2008 | 12:39 AM
joe f350's Avatar
joe f350
i would but i dont know it
Old Dec 22, 2008 | 08:59 AM
fonefiddy's Avatar
fonefiddy
get abushingkit fromford about20
Old Dec 22, 2008 | 09:52 AM
starmilt's Avatar
starmilt
fonefiddy in your signature you mention velvet ride can you tell me something about this and how you like it. Plus what is a turbo bumper thanks.
Old Dec 22, 2008 | 12:19 PM
joe f350's Avatar
joe f350
a bushing kit form ford about 20 bucks right
Old Dec 22, 2008 | 12:51 PM
  #28
starmilt's Avatar
starmilt
Joe he's talking about the plastic bushings in your pedal assembly very common for these to wear out and causing a little slack before it pushes the clutch rod again on these clutch settups it takes very little slack to cause problems.
Old Dec 22, 2008 | 01:14 PM
  #29
joe f350's Avatar
joe f350
ok i will look
Old Dec 22, 2008 | 02:29 PM
  #30
Dave Sponaugle's Avatar
Dave Sponaugle
Look at the pin on the arm where the clutch master cylinder attaches to it.
That plastic bushing is probably gone.
How far do you have to push the pedal down before you feel resistance in the clutch pedal?
