keep eating u joints
Old Dec 21, 2008 | 12:49 AM
joe f350's Avatar
joe f350
when i was drive witha lead body part to wink wink and my rear ujoint feal apart but it happen when i was drive 15 mph while pulling in to my drive way my mom thinks my gframe it twisted it dont she say my frame is bent and causeing more stress for my u joint but my holing clipps faild and the caps poped off plz help house hold is aurging very bad about this
Old Dec 21, 2008 | 01:09 AM
ke5adb's Avatar
ke5adb
Which u joint is it? if it is the rear one, check you yoke and make sure its still tight. I have to tighten mine back up about every 2 months. Might make sure you're not over-tightening your u-joints caps. If its the ones in the middle (on a 2 piece shaft) you might check your carrier bearing. Check you driveline to make sure your slip yoke has room to slip. It might be bottoming out and that will put a side load on it.
With my 4.11 rear, I know if I drive my truck over about 70 alot, I'll have to change them out alot more often. Your are better off buying the greaseable type, than the permanently lubed ones. That way in wet weather, or if you go mudding alot, you can push the water and other junk out of them.
When you replace your joints, take a small screwdriver and clean the grooves out where the clips sit. after you get your joint and retaining clips in, smack the yoke with a 2 lb hammer so it kinda sets the u-joint. grease them really good. Make sure your yokes aren't egg-shaped either. I've seen quite a few like that.
Old Dec 21, 2008 | 01:13 AM
starmilt's Avatar
starmilt
If that is the new yoke you just replaced are you sure you had the right ujoint.
joe f350's Avatar
joe f350
the rear one i just replace the yoke about a week ago going to to the pinon yoke the cap on the drive short can off
Old Dec 21, 2008 | 01:20 AM
starmilt's Avatar
starmilt
If it didnt break the ujoint or the yoke and the yoke on the driveshaft is not damaged from when you twisted the yoke it was not properly installed.
Old Dec 21, 2008 | 01:28 AM
Greywolf's Avatar
Greywolf
U-Joints go to pieces when the shaft is out of balance.
I'd have the driveshaft spun, or just replace it with a known straight one.
An out of balance condition can also destroy both the input shaft bearings of the axle and the transmission output shaft.
BOTH are expensive, so it would be good to verify it.
If anyone "HIGH CENTERED" the truck (even without your knowing) it might explain it.
A bent shaft WILL BE out of balance.
Don't let stupid people drive your truck....
Old Dec 21, 2008 | 01:40 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
As with the ballance, I would Also check and make sure your driveshaft is in time if its a 2 piece. Both yokes on the end of each shaft should be the same on both ends of that shaft. If it has a slip joint, it could have possibly been slid apart and when put back togheter, it may not have been timed. Another place is where the yoke bolts through the carrier to the other driveline. It could have been bolted on without being checked for time. Check it out.
An out of time drive line, (unless perfectly stright, which yours is not from carrier to axle) it can cause bad vibration, stress on drive line and will quickly and prematurly wear out u-joints, yokes and pinion bearings, ect. Since your truck is lifted, the angle to the axle is probably very great.
This is only for a driveline with 2 shafts and a carrier, A single driveshaft should not have this problem unless assembled wrong. So again this may not apply.
Old Dec 21, 2008 | 01:47 AM
starmilt's Avatar
starmilt
I forgot about the lift on your truck you may have angle problems or spring wrap problems.
Old Dec 21, 2008 | 01:50 AM
joe f350's Avatar
joe f350
ok i will check it all out thx guys
Old Dec 21, 2008 | 01:51 AM
FORD MEGA CAB!!!
Also, Everytime I replace U-joints at work I replace the U-joint straps and bolts. Even If they were taken off so the truck could be towed, I still change the caps and bolts.
They sell what you would call a u-joint Strap kit at the parts stores. I never replace a driveline with the old caps in bolts unless I have to. Also, the new bolts should come with locktite on them or at least lock washers. If it don't, put a dabb of lock tight on them. I use red cause Im parinoide. (red is the tough lock tight)
If not properly torqued and or locktighted, they can back out and cause a major disastor on the freeway. Trust me, I have seen a few and its not pritty. Expecilly on the semis where the driveline weighs near 100lbs. You otta see one of them bad boys fly!!! You have to see it to belive it!!!
New u-joints = new Straps and bolts
Removed driveline for any reason= new straps and bolts
Its cheap and can save your ***.
Old Dec 21, 2008 | 01:55 AM
joe f350's Avatar
joe f350
what i think may have happend is the clips failed i can feal my traany going out i had it rebulid abot 1000 a no somthing up it geting harder to shift and dosent want to go in gear and if feal like the cluct is sliping had that changed when traany i think the shop did a half *** job iam haveing to fix
Old Dec 21, 2008 | 01:56 AM
joe f350's Avatar
joe f350
i put new strap new i put the new pinion yoke on 3 weaks back
Old Dec 21, 2008 | 02:02 AM
starmilt's Avatar
starmilt
What do you have for lift in the back blocks or springs with 8 inches if they didn't adjust the rear end angle you may have problems forever.
Old Dec 21, 2008 | 02:08 AM
joe f350's Avatar
joe f350
it mostly blocks i tink maybe 5 inch blocks i thing the lift is for a 79 f250 thats what my front axle is out of
Old Dec 21, 2008 | 02:09 AM
joe f350's Avatar
joe f350
how do i ajust it so i wony have prolbems
