play up and down, or are you talking going from throttle to coasting? I know when my yoke loosens up every once in awhile, especially after I pull something way too heavy, I have a vibration and usually break out the 3/4" drive sockets and tighten it back down. The vibration goes away. Usually only has about 1/8" up and down play, about the same as a really worn u-joint.
ok. I know how much it sucks waiting on money to fix something. I have to wait til after xmas before I can find a 4 or 5 speed to put in that 89 half ton i just bought for $75.
are you greasing the u-joints when you put them in the come pre-greased but its not sufficient for them to last long ya gotta put them in then grease them.im doin both my u-joints on the front shaft in the morning at work gonna pop the bad one out in a press.cause its stuck!!
Not to sure about stairt but in the picture in your gallery the driveshaft looks like there is no angle where it connects to the rearend may be an optical illusion. But beeing too straight will cause a vibration too. I dont know how yours can be to straight the angle needs to be the same at both ends.
