keep eating u joints
Old Dec 24, 2008 | 03:58 PM
  #61
joe f350's Avatar
joe f350
iam about to buy a dana 60 front for 1000 and slap it under my front end
Old Dec 24, 2008 | 04:03 PM
  #62
starmilt's Avatar
starmilt
Go for it want one myself.
Old Dec 24, 2008 | 04:04 PM
  #63
joe f350's Avatar
joe f350
i sell u it for 1700
Old Dec 24, 2008 | 04:13 PM
  #64
starmilt's Avatar
starmilt
I'm CHEAP.
Old Dec 24, 2008 | 04:18 PM
  #65
joe f350's Avatar
joe f350
i some aim i my loacl 4x4 shop i call them rip offs are us they want 1700 for a 60 and the idot says no dana 60 track bars
Old Dec 24, 2008 | 04:33 PM
  #66
starmilt's Avatar
starmilt
IS it just me or does Joe sound excited about this D60.
Old Dec 24, 2008 | 04:37 PM
  #67
joe f350's Avatar
joe f350
ya u say ur cheep but u pay for this site
Old Dec 24, 2008 | 04:38 PM
  #68
smokey98's Avatar
smokey98
I hope somebody took the time to wrap it for him.
Old Dec 24, 2008 | 04:40 PM
  #69
joe f350's Avatar
joe f350
it was the gift to my self
Old Dec 24, 2008 | 04:49 PM
  #70
smokey98's Avatar
smokey98
The best kind.
Old Dec 24, 2008 | 04:51 PM
  #71
joe f350's Avatar
joe f350
know i just need to slap it under my front end
Old Dec 24, 2008 | 05:35 PM
  #72
Dave Sponaugle's Avatar
Dave Sponaugle
U joints live better with some angle between the driveshaft and pinion shaft.
What I can't figure out is with a lift, and a crew cab there should be a lot more angle than what I see in the picture.
That is flatter than mine is at stock height.
That picture is taken from the side, it just looks to straight.
These are vacuum lines to control the heater doors.
This plug used to go to the low vacuum warning sensor.
This is a rats nest.
You will learn a lot about vehicle wiring, I can tell you have lots of homework.
Old Dec 24, 2008 | 06:49 PM
  #73
George D.'s Avatar
George D.
Yeah that driveline angle definately doesn't look right almost like the pinion is turned up too much. Does it have any angle shims already on it? I don"t get how thats lined up like that with that lift.
Old Dec 24, 2008 | 07:12 PM
  #74
joe f350's Avatar
joe f350
what do u guy think i should do i will put more pick of the drive line up i thought only the wiring was mest up
Old Dec 24, 2008 | 10:37 PM
  #75
Dave Sponaugle
Joe take another picture from a little farther back.
That one is really to close to get a feel for the pinion to driveshaft angle.
Also is your driveshaft a two piece unit?
What does the angle look like there?
Same for the transfer case output shaft to drive shaft.
From what I am seeing, I don't think you have as much lift installed as you think.
A few pictures of the rear axle front spring hanger, rear spring hanger and the axle spring block will answer that question.
If you do have much lift, someone has dropped the carrier bearing down already, possibly to far to make up for the driveshaft length being to short.
Do those locations again for the front axle.
How does the front driveshaft look where it attaches to the transfer case and axle pinion?
Now two more electrical questions.
Is the fuse panel mounted to anything or is it just hanging there?
And did your alternator start charging after you grounded the voltage regulator?
