Sponsored by: Real Truck
Adjusting shift points
Old Dec 20, 2008 | 09:20 AM
mudlift's Avatar
mudlift
I have a 2004 F350, 6.0 powerstroke, airaid intake & 4" magnaflow dual exhaust. I mainly use my truck to tow a 9000# camper. I'm going to install a Hypertech Max Energy programer today. Any recomendations on where to set the shift points?
Old Dec 20, 2008 | 09:54 AM
ReAX's Avatar
ReAX
With my experimenting, their isn't a lot of slack in gas tunes. My recommendation would be to try and max each out so you know your limits. Then cut the difference in half. If it's close to gas tuning, 1-2 +100rpms, 2-3 +200 rpms, 3-4 +300rpms. These were just under my limits, 1-2 didn't shift at +200, 2-3 didn't at +400, I never did max out 3-4.
Old Dec 20, 2008 | 10:22 AM
mudlift's Avatar
mudlift
I reckon I will try that, I just don't want to screw anything up.
Old Dec 20, 2008 | 10:44 AM
ReAX's Avatar
ReAX
You should be able to damage anything with shift points, just be prepared to not have a higher gear than your testing. With my software, I was able to shift by feathering the pedal, it reduced the rpm and changed the tps enough to command a shift.
ommegang
2009 - 2014 F150
19
Apr 10, 2012 06:32 AM
mikerans
Aug 8, 2011 09:59 PM
hdman6
Jan 14, 2008 10:06 AM
liquid 1
1997 - 2003 F150
20
Mar 23, 2007 07:32 AM
Thumper4995
Sep 10, 2003 09:07 PM
