Sponsored by: Real Truck
ABS light, OD light flashing
Old Mar 18, 2002 | 03:07 PM
mgriffin's Avatar
mgriffin
Old Mar 19, 2002 | 07:31 PM
KY350SD's Avatar
KY350SD
I have recently purchased a 2000 F350 SD with PSD and auto Tranny. It started raining Sunday night, when I left for work my ABS light came on. Then once I got up to speed 45-50 the OD light started flashing and the speedo started jumping around. Once it quit raining and dried up a little it quit. It started back today but, so did the rain. Also, noticed a problem in the climate control. Left the selector on defrost and floor fan on high and hit the fob to lock the doors before getting out and the fan came on. Sorry to have so many questions just hoping that someone can help.
Old Mar 19, 2002 | 09:20 PM
Monsta's Avatar
Monsta
Sit. Stay.
GAD! Electrical gremlins! Thousands of 'em! Please, go see yer dealer right away!! It's still under warranty, right?
There is good news, though. When those lights lit, it threw a code(s). Your dealer can read them to help them pinpoint the troubles.
Old Mar 20, 2002 | 03:58 PM
KY350SD's Avatar
KY350SD
Thanks for the reply Monsta. Unfortunately the truck has 43K miles and is out of waranty.
I have an OBDII scanner and have conneted it to the hook up under the steering wheel and did not get any codes. I do not know where to check the tranny or ABS and do they use a different type of connector or are the OBDII as well?
Any help or suggestions would be greatly appreciated.
Thanks,
Jody
Old Mar 20, 2002 | 05:40 PM
NoMo's Avatar
NoMo
Check the speed sensor that is mounted to the top-front of the rear differential housing. Sounds like maybe it's not plugged in good & tight.
augim62
Sep 19, 2016 11:09 PM
aparamburo
2004 - 2008 F150
Dec 15, 2012 09:52 AM
gtex
Nov 18, 2002 02:04 PM
stevieray
Sep 18, 2001 05:36 AM
