harmonic bal. install?
thanks
chris
this homemade tool and a 50's metal dinning table leg for a cheater pipe...
http://www.panix.com/~alvinj/file12/...icbalancer.jpg
I got jumped about that tool because some guy knew some guy that lost an
eye to a file braking when he was using it as a pry bar.
That's an annealed (normalized actually;) file I was going to make a knife out
of ... see how the end is curved up where the knife's point was going to be? :)
And notice the holes I drilled through the sucker too? ;)
It ain't hard anymore. Nicholson brand file BTW. ;)
Anyway I carefully measured the hole distance my 360FE's harmonic
balancer has and shoved 3/8" bolts through those holes and through the
file/handle and that's all there was to it. They are a weird spacing on mine
and needed 1/32" measuring to get it right.
The key tricks here is the hole spacing and the need(?) for something that
isn't plain ol' straight edged. A little hand grinder will make quick work of
a piece of straight edged steel tho! ;)
Alvin in AZ
ps- more crazy stuff...
http://www.panix.com/~alvinj/file12/halfinchopenend.jpg
talkin' about something that could fly to pieces! ;)
That sucker is ~65hrc M@ high speed steel, tooth-to-back.
But it worked great on the thin jam nut on the end of this...
http://www.panix.com/~alvinj/file12/damper&shock.jpg
...and it's really a 9/16" open end BTW. ;)
Don't need it anymore anyway because I made a 3/8" fine
thread jam nut from a 5/16" jam nut. :)
pps- Most "problems" just take a little Injun-new-it-tee is all ;)
ppps- and one more from a file...
http://www.panix.com/~alvinj/file12/Ford9inch-B.jpg
http://www.panix.com/~alvinj/file12/Ford9inch-S.jpg
http://www.panix.com/~alvinj/file12/Ford9inch.jpg
The file is threaded and the bolts are turned into those threads
tight then the jam nuts were added then the bolt cutting last.
pppps- bed frame steel and exhaust manifold studs... ;)
http://www.panix.com/~alvinj/file12/yoketool.jpg
Set for taking it off... flip it over for putting on the nut. ;)
The longer piece I've used forever, has holes drilled in to hold
things like air-cooled VW flywheels and my FE flywheel too. ;)
Is the PS pulley also slightly angled and not parallel with the other pulleys?
Easy as that. ;)
What's the harmonic balancer tool look like?
How does it work?
Alvin in AZ
the harmonic balancer looks like this
Eastwood Co. - Harmonic Balancer Installer
I went ahead and bought the puller/pusher set and it's turned out handier for
the neighbors than for me so far. LOL :)
Alvin in AZ
What did yo finally go with internally ? I spied the performer intake, non adj rockers, but the rest is a mystery "LIKE ALL FE's from the outside" lol Hoping John treated you right on the thing.
p.s. thanks again for the crank!
