Heater blow problem
Old Dec 16, 2008 | 02:51 PM
jb10's Avatar
jb10
Heater blow problem
Hey guys. It's been awhile since I have been logged on here.
Any way it's below 0 in Colorado and I am having a heater problem.
The blower only seems to blow on one speed, low.
The blower is working but it only blows on low no matter what I change the fan speed setting to.
Btw this is on a 78 F150 4x4 with a/c.
I searched but didn't find anything with this same problem.
Thanks in advance for the help.
Old Dec 16, 2008 | 03:12 PM
firstonraceday's Avatar
firstonraceday
Sounds like the blower motor resistor. Not sure on a/c equipped trucks, but on mine without a/c, it's located in the ductwork under the dash on the passenger side. It has wiring plugged into it and a couple of screws holding the resistor into the ducting.
Old Dec 16, 2008 | 03:17 PM
bucks77ford's Avatar
bucks77ford
I was thinking the same thing. You can see in this pic where the resister is on the ductwork.
Old Dec 16, 2008 | 03:36 PM
IowaHighBoy's Avatar
IowaHighBoy
That is a GREAT picture...
It does not by chance show where I drill the small hole to spray lube into the Fan or blower Motor.
Thanks for your help!!!
Cedar Rapids, 3" of partly cloudy.
Old Dec 16, 2008 | 03:38 PM
Alvin in AZ's Avatar
Alvin in AZ
I was not thinking that. :/
I was thinking your "speed" selector switch is bad.
Don't know '78's setup. :/
On my '75 the hi-contact bypasses the whole resistor pad.
When does the blower run?
...when the selector switch is in any position?
Or what?
Alvin in AZ
Old Dec 16, 2008 | 03:40 PM
jb10's Avatar
jb10
yeah it runs when it is in any position.
Old Dec 16, 2008 | 06:05 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I agree with the above, the switch is bad.
The resistor is low and medium and then it is bypassed for High.
Josh
Old Dec 16, 2008 | 10:18 PM
bucks77ford
Let us know what you find out. The resister was my first guess and then the switch. But, from what Alvin and Bullitt posted, it sounds like the switch. That way if mine does the same thing I'll know what to replace first. So, if the resistor is bad, will the speed just be high?
Old Dec 16, 2008 | 10:57 PM
Bullitt390's Avatar
Bullitt390
If the resistor goes bad you'll have nothing in low-mid, but full power in high.
