limited slip
Old Dec 22, 2008 | 09:38 PM
Ryan50hrl's Avatar
Ryan50hrl
Where are you driving your trucks....keepin on the road always?
Old Dec 23, 2008 | 01:15 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
limited slip = yes
locker = no unless your rig sees offroad for the majority of it's life.
a limited slip will help in all traction situations
Old Dec 23, 2008 | 06:17 AM
Catmonkey's Avatar
Catmonkey
You can always install a mechancial locker (i.e Detroit Locker) or an electric locker in your truck. Mechanical lockers have some rather strange handling quirks on the street. The electric locker can be turned off, but it's rather expensive. Limited slip differentials can lose their effectiveness over time, especially if you don't keep your tires inflated to the same pressure or have different tires on the same axxle. There are better limited slips than Ford uses. I'm saying they're available, but I don't know that for a fact. I haven't looked into this yet. What rear axle is for using in the 4x4s? Is it the 8.8? It looks bigger than the one in my 92 Bronco.
Old Dec 23, 2008 | 12:24 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
4.6 engine has the 8.8 axle and smaller trans
5.4 engine has the 9.75 axle
Old Dec 23, 2008 | 01:04 PM
Catmonkey's Avatar
Catmonkey
Yeah, I crawled under there this morning and figured it was the 9.75 based on some info I found.
How do you like that Roush supercharger? I think I'm going to be installing one after I get a few more miles on this thing.
Sorry
Old Dec 23, 2008 | 01:14 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
was probably the best money I've ever spent on a vehicle...getting some tunes shortly...and then it'll be even better.
Old Dec 23, 2008 | 01:17 PM
Catmonkey's Avatar
Catmonkey
I understand it's a well engineered kit.
Old Dec 23, 2008 | 06:23 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the parts/pieces go together as intended. and it started on the first try and never had a problem since
but Roush needs to spend some time ensuring the directions are up to date...the install directions suck horribly. A novice wrencher should steer well clear
Grogtronics
Oil & Lubrication
Sep 9, 2008 08:14 PM
txflyyaker
2004 - 2008 F150
18
May 18, 2006 11:52 PM
brncobilly
1978 - 1996 Big Bronco
Feb 24, 2002 09:33 PM
Vaccuum
Sep 28, 2001 05:28 PM
proeliator
Offroad & 4x4
Aug 29, 2001 04:55 PM
