01 Navigator door panel removal
Old Dec 15, 2008 | 02:00 PM
d4ster3's Avatar
d4ster3
hey guys, just found this forum..
we had a big freeze last night and after trying to roll my passenger window down, my door handle started moving in like someone was pulling it.. basically I think the window is off track and something has fallen down but to find out I need to remove the door panel.. Ive tried pulling up, pulling in, looking for screws and everything else.. I know theres got to be screws that need to be removed but I cant find any!! HELP!!
thanks
Old Dec 15, 2008 | 02:38 PM
alloro's Avatar
alloro
This thread might help.
https://www.ford-trucks.com/forums/7...r-removal.html
Old Dec 15, 2008 | 03:00 PM
d4ster3's Avatar
d4ster3
ive taken off the triangular piece at the top,and removed the screw there, ive take off the door handle and screw, but i dont see any other place... i took out the courtesy light but theres no screw in there..
Old Dec 15, 2008 | 07:03 PM
alloro's Avatar
alloro
By the courtesy light, you mean the one down low on the door where you pry just the lens off?
Pop out the power window switches, there could be one behind there. Once all the screws are out you lift the door panel upward and outward.
Old Dec 15, 2008 | 08:42 PM
d4ster3's Avatar
d4ster3
yes, the courtesy light down low.. I popped the lens off and also popped out the light and plastic that holds it.. theres not a screw that i see, all i see is some type of plastic clip that you can barely reach.. I have taken the lock/window switch and do not see a screw in there either..
Old Dec 15, 2008 | 08:57 PM
d4ster3's Avatar
d4ster3
i see the screw inside of where the lock/window switch is but theres no way to get to it without taking off the armrest.. i dont see any way of taking off the armrest without tearing it up.. little help??
Old Dec 16, 2008 | 09:17 AM
alloro's Avatar
alloro
I did some looking around and found a few places that mention that a navigator door panel (unlike an expedition door panel) is held on by retaining clips behind the panel. They say that these panels have to be pried off.
Old Dec 16, 2008 | 11:15 AM
d4ster3's Avatar
d4ster3
nope no clips, it was the damn handle.. there were 2 screws, one of each end of it.. anyway, i figured it out.. thanks for the help
Kwikkordead
31
Jan 5, 2017 08:15 AM
yogmuney
Dec 16, 2011 07:56 PM
ExpySport
Feb 8, 2010 08:25 PM
dmcenery
2004 - 2008 F150
Oct 25, 2008 09:52 AM
edgescreambeauty
Mar 2, 2007 12:45 AM
