03 Expedition Door removal
Old Apr 23, 2008 | 05:11 PM
lkborg's Avatar
lkborg
How do you remove the driver's door panel? Do you need a special pry bar if so what is it called? Thanks loads. My dealership was not helpful at all.
Old Apr 23, 2008 | 10:21 PM
sbclemens's Avatar
sbclemens
On my 98 you have to remove screws located behind the plastic trim on the driver's side mirror(pull up and out), lamp above the pocket at the bottom of the door(pry off carefully), underneath the window controls (pry off carefully) and the door handle. Lift the panel up and out.
Old Apr 24, 2008 | 01:10 PM
Mark62's Avatar
Mark62
Yep, on my 99, 3 screws plus door handle and it comes off...
1. located behind the plastic trim on the driver's side mirror; remove trim - pull out then up.
2. inside the lamp at the bottom of the door; pry off cover from the bottom .
3. underneath the window controls; pry up carefully & evenly front and back.
4. Remove door handle - one bolt
Old Apr 24, 2008 | 06:15 PM
lkborg's Avatar
lkborg
My door does not have a separate trim for the mirror, it is one molded piece with the door panel. But I will look again and see if I can do it with the rest of your instructions. Thanks for your help.
Old Apr 25, 2008 | 02:31 PM
shakespearesdad's Avatar
shakespearesdad
I took my '03 Expy to a local stereo shop. The 17 year-old kid charged me $30 to remove and re-install the panel. Took about 4 minutes to remove and it wasn't damaged at all.
Old Apr 26, 2008 | 07:37 AM
broncoholic's Avatar
broncoholic
Click here for instructions. Andy-Expy03 gives good detailed instructions in the 3rd post of the thread. I pulled mine off about 2 years ago by just going slow and feeling my way through it.
Diesel_Brad
Apr 20, 2025 07:28 PM
Bigpipes 35
Sep 24, 2012 11:41 AM
bigmacmonday
Jun 16, 2010 03:59 AM
billy13
Dec 14, 2009 10:29 AM
Voksboy
Jan 23, 2004 07:47 AM
