2000 2WD - Brake Rotor Replacement
New to the forum, but not necessarily to rangers. My first vehicle was an '87 ranger, which I have passed on to my dad, and he has now moved through several of them since.
His latest one is a 2000 2WD with the 4 cyilinder engine. He is looking to have me help him change his brake rotors out, and Im just trying to figure out which ones to actually buy.
It looks like from the various parts searches I have done, that the rotors come with a bearing and the lugs already installed? All of the previous brake jobs I have done the rotor just slides back over the lugs, it didnt include them.
However, I see some of the rotors for sale that dont have the lugs on them. Im just slightly confused as to what are the right parts to buy, and whats going to change if Im doing a rotor that includes the lugs/bearing.
Sorry if this is a repeat post, I have done a search and couldnt find anything that was specific to this.
Thanks in advance!
~Bug
Thanks for the quick, and very through reply! So all this really turns into is a brake job + a bearing replacement at the same time.... I have just never seen the bearing races in the rotor before, it has always been a separate piece.
I very much appreciate the time you put into the writeup! Ill make sure to print while working away on it in a few weeks.
Is there an easy way, short of taking off and measuring, to determine what diameter rotors are on the truck? I see waaaaay too many options when I try to buy them....
I have had the problem with the parts guy (depends on who I get) because there are two different rotor sizes for the same truck. At this point Im just looking at rockauto.com to get an idea of whats out there.
If I understand you correctly, the bearing races are pressed into the rotors already, along with the lugs, correct? So to buy new bearings, I just need an inner and outer cone? (Sorry, I know, very newbie questions)
I just am looking at different bearing kits from Napa, Advance Auto and RockAuto and Im not sure what all of the differences are...
Thanks!
Its rear wheel anti-lock, not the four wheel, so that eliminates that variable. I think I now have it narrowed down, since the last thing to check is just coil springs or torsion bar (according to the online parts listings). Ill check when its not dark out to see which it has, but Im assuming torsion bar. (Who knew there were so many options on one little truck?)
Sorry for the delay, but with the holidays I havent been near the computer too much.
We are about to tackle the brake job today. Its finally going to be warm/dry enough to tear into things (here in upstate NY) that we can get to it.
Hopefully Ill have good news to report by the end of the day, or Ill be posting back on here for more helpful tips if it doesnt go well
Thanks for checkin' in on me!
Well, Im guilty again of being lax on the replies... Its hard at home since the folks have Dialup...so it takes about 5 mins to get this page to load up....
The right answer to "how did it go" is really that it didnt....
we pulled the front wheels, and looked at everything, and the front brake system was in great shape. My guess is that someone had already done some work on it. My dad had said it was the front based on the shimmy he had when braking, so I got all set to do a front brake job.So, we put the fronts back on, and pulled the rear wheel. I could barely turn the hub, and then it just broke and spun, and then caught again... not a good sign. We pried the drum off, and it was clear from looking at the wear spots on the inside that the drum was very out of round. It was a run to the parts store to get drums and shoes, and we slapped everything on the one side. On the other side, the drum slid right off, which was strange. Turns out that the lining had separated from the rear shoe, so that just fell out when we pulled the drum. Good thing more bad things didnt happen before we got to it.
So, while I didnt need to do the front brake job, we DEFINITELY needed to do the rears. I really appreciate your detailed responses! If I run into any other troubles, Ill make sure to post a few new threads! Happy New Year to all!
