2008 intercooler
Old Dec 14, 2008 | 06:49 PM
green 69's Avatar
green 69
2008 intercooler
HI everybody, quick question, has anybody or will it work put an 2008 6.4 intercooler on a 7.3? and just bought an drop pitman arm for my 5" lift but it hits the big bolt head on the trac bar and the trac bar itself.. Im I to grind some off the bolt to work and the trac bar mount...
Thanks for any help..
Old Dec 14, 2008 | 07:04 PM
HookedOnFuel's Avatar
HookedOnFuel
You can use the 2008 intercooler if you swap header panel, frame horns, bumper and mounts, headlights, hood and grill, fenders, radiator and condenser. Now you're just short of some misc nuts, bolts and small parts. When you get done retrofitting the '08 intercooler you will have retrofitted an '08 front end. Good job!
As for the drop pitman arm. Sounds like the one you got is too long.
Old Dec 14, 2008 | 07:08 PM
green 69's Avatar
green 69
Thanks for the heads up, sounds like alot to change out for an 08 intercooler
as for the drop pitman arm just doesnt have the right bend I guess.
I'll plan on shipping it back with a note..
Old Dec 15, 2008 | 01:15 PM
a-rod's Avatar
a-rod
Yeah you wont get an 08 intercooler in there without tons and tons of work. Just put a 6.0 intercooler in.
heathrunkles
Jan 24, 2011 09:21 PM
powerstroker100
Sep 24, 2010 02:31 PM
swamper38s
Jul 11, 2008 02:41 PM
Gordondavis
Sep 30, 2006 07:04 PM
basstardo
Oct 15, 2005 04:01 PM
