Sponsored by: Real Truck
Front suspenstion torque specs
Old Oct 15, 2005 | 02:06 AM
basstardo's Avatar
basstardo
Anybody have the torque specs for the following:
Front u-bolts
Upper trac bar bracket
Trac bar bolts
Thanks,
Terry
Old Oct 15, 2005 | 12:23 PM
Rongold's Avatar
Rongold
Talking Bolt Torque
I assume that your truck is a 99-04 model being that you are asking for U-bolt torque.
According to my 03 shop manual, the U-bolts are 99 ft/lbs, and the track bar bolts are a whopping 406 ft/lbs. There are no specs for the track bar bracket, but there is a general chart showing torque specs for different size bolts.
3/8 bolts 37 ft/lbs
7/16 bolts 61 ft/lbs
1/2 bolts 90 ft/lbs
9/16 bolts 130 ft/lbs
5/8 bolts 178 ft/lbs
3/4 bolts 259 ft/lbs
7/8 bolts 420 ft/lbs
1 inch bolts 634 ft/lbs
These figures are for the actual bolt size---NOT the head size.
Make sure that you tighten everything with jack stands under the front axle supporting the weight of the truck, or with the truck on the ground. If you tighten everything with the suspension hanging, you might wind up with a leaning truck.
RON
Old Oct 15, 2005 | 04:01 PM
FortyFords's Avatar
FortyFords
front u-bolts -133nm-99ft/lbs MAKE SURE YOU USE NEW U_BOLTS!
don't want to find you in a ditch if the old ones break!
trac bar bracket to the frame bolts 35 ftlbs
trac bar bolts 369 ft lbs upper and lower
Rich
pkthomas
Crossovers
Apr 23, 2014 09:15 PM
abranz
Jan 23, 2013 12:56 PM
timf150
Apr 2, 2012 03:34 PM
390XR7
Oct 3, 2011 09:21 PM
Gordondavis
Sep 30, 2006 07:04 PM
