Front Hub Thrust Washer
Old Dec 13, 2008 | 10:09 PM
Scruffy's Avatar
Scruffy
So I just got done R&Ring my front hub bearing using Guzzle 92 post on servicing the hub bearings it was a breeze. His instructions were right on, however I wish he covered removing and replacing the main seal on the outer shaft. He suggested I purchase the seal installer OTC-6695 but I didn't have time to wait. I went to the local hardware store and I made one from 1 1/4" water pipe and the floor mount flange that is talked about on this site. It worked well. Now for my question: I did the drivers side first and it did not have a thrust washer (with the 4 grooves in it) I have manual locking hubs. Then when I did my passenger side it had a thrust washer. Me like a dumb *** was in a hurry and forgot to install it when I was reassembling my hub. Is it nessecary to have it in there with my manual locking hubs? Or can I run with out it? This is the 2nd time for bearing for me at 256,000, seems like they last for an average of 125,000 miles.
Old Dec 14, 2008 | 07:05 AM
SGnAZ's Avatar
SGnAZ
I believe the washer you are talking about is to let the vacuum pulse of air through to the auto hubs.Manual hubs don't need the vacuum,so I think you're ok without it.Someone will correct me if I'm wrong.
Old Dec 14, 2008 | 07:15 AM
erebus's Avatar
erebus
I have the manual hubs and they were their. My drivers side hub was worn so bad that this washer was worn half way through. I replaced both incase it was a spacing issue. Does anyone know why ford made them out of plastic and not metal?
Jrod
2001 F350 Reg Cab,Auto,4X4 PSD
Old Dec 14, 2008 | 07:22 AM
mueckster's Avatar
mueckster
With the thrust washer out, the manual hub will still function OK. I would put it back, asap, because the large axle seal, in the knuckle, may wear out quicker from the movement of the axle (in & out), when turning the wheels, without the thrust. The seal is basicly holding the axle from moving right now.
Old Dec 14, 2008 | 07:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Sure.
For one thing, it's a hell of a lot cheaper, and parts made from plastic usually wear out faster.
What some of y'all may not know is, all the automakers are really in the partsbiz, where most of their profit comes from.
If parts don't wear out, none will be sold and there goes the profit.
Old Dec 14, 2008 | 07:25 AM
mueckster's Avatar
mueckster
Jrod
Probably, a cost saving issue. But with proper maintenance, it will last the life of the truck.
But, I also agree with you, Bill. If they didn't wear out, they couldn't sell more.
Old Dec 14, 2008 | 10:18 AM
SpringerPop's Avatar
SpringerPop
Bill's right, of course.
So, if we all did our preventive maintenance regularly, we'd be sure to drive Ford into bankruptcy?
Hmmmm, more money left in my pocket, less in Ford's. Yup, that's what I was aiming for.
But then there'll be no parts!
I didn't realize that I'M the root cause of this "bailout"!
Damn, I better let some stuff go.......
Looks like the ESOF's going to have to start sticking. Guzz has great instructions on rebuilding them auto-hubs, so I guess I should use 'em to take them apart and just throw some dirt in them.
Think of me as a patriot!
Ford should be thankful that everyone doesn't know about this site!
Pop
Old Dec 14, 2008 | 12:27 PM
Scruffy's Avatar
Scruffy
Thanks for the replies guys. I guess I will take my hub back off and reinstall the thrust washer. Like I said above the drivers side didn't have one and when I took my hub off the hub was riding against the thrust washer. So I guess I should go get one for the drivers side then also.
slour
Aug 5, 2017 11:28 PM
texbigred1
Nov 2, 2016 09:32 PM
Karjalanwarrior
Mar 24, 2012 06:34 PM
LSO1123
Jan 23, 2012 07:37 PM
lucaslaw
May 22, 2010 07:10 PM
