Removed my hub
Old Aug 5, 2017 | 08:05 PM
slour's Avatar
slour
Removed my hub
So I removed my front driver's side hub today and during the process it seemed like an inner washer in the thrust bearing came apart in three pieces. I'm having a very hard time finding a part number or proper description for this part. If I'm not describing this properly it was the part that held back the spring in the hub.
Thanks for the help.
It's inside of part 1A052
Old Aug 5, 2017 | 08:27 PM
lafermedavid's Avatar
lafermedavid
Quad 4x4 Montana Torque King 4x4: Home Page
Old Aug 5, 2017 | 10:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe this will help? Hang in there numberdummy or mikeo0o0o0 will come along with the part# here shortly.
I was almost in the same predicament, I was missing a "Spring Retaining Ring" thanks to a PO, till mikeo0o0o0 hooked me up with the diagram/part # and several locations that had it on hand.
Old Aug 5, 2017 | 10:29 PM
slour's Avatar
slour
It should be part of part 12 but the little ring that broke off isn't listed.
Old Aug 5, 2017 | 10:34 PM
77&79F250's Avatar
77&79F250
Sounds like you will need and new Inner Clutch Ring and Bushing Assembly.
Old Aug 5, 2017 | 10:42 PM
slour's Avatar
slour
Any idea of a part number or where I can get it?
Old Aug 5, 2017 | 10:43 PM
77&79F250's Avatar
77&79F250
It comes attached to 1A052 or come in the box with a new 1A052. I went up to the shop and dug around this is what you need to get to get a new small piece that the screwdriver is pointing to.
Old Aug 5, 2017 | 10:46 PM
77&79F250's Avatar
77&79F250
All from mikeo0o0o0 a while back.
Front axle parts are a royal pain with Fords.
Here's what the catalog shows.
According to the parts catalog, there are five different axles and parts lists.
It shows a 3800 lb capacity w/ free running hubs uses parts list 30.5Q
same without free running hubs uses parts list 30.5P
4500 lb capacity, 3.54 ratio w/ free running hubs uses parts list 30.5S
same without free running hubs uses parts list 30.5R
and finally 4500 lb capacity w/ 4.10 ratio uses parts list 30.5AA
I figure I can discount the two without free running hubs
The parts list for these axles (except the 30.5AA) is in section 30.5 page 12 of the text section of the parts catalog.
I have a strong suspicion you have the 3800 lb axle with free running hubs (parts list 30.5Q) The two part numbers you're looking for are C4TZ-1A052-A and C4TZ-1A055-A.
C4TZ-1A052-A last dealer cost $39.18, list $65.30
Wesley Obsolete Parts, Liberty, KY has 1 (606) 787-5293
Bob Allen Ford, Overland Park, KS has 3 (913) 381-3000
Dennis Carpenter, Concord, NC has 2 (704) 786-8139
Green Sales, Cincinnati, OH has 32 (800) 543-4959
Parts International, Farmers Branch, TX has 3 (972) 241-8730
Pioneer Garage, Highmore, SD has 2 (605) 852-2122
Wolfe Ford, Lidgerwood, ND has 2 (701) 538-7337
Big Johns Ford, Minden, NE has 1 (308) 832-1640
Atkins Motor Co., Atkin, MN has 1 (218) 927-2169
Wright County Motors, Clarion, IA has 1 (515) 532-6603 I got mine form them for $14 and some change. Freight was more than the part....
C4TZ-1A055-A no final prices listed
Wesley Obsolete Parts has 2
McDonald Obsolete Parts, Rockport, IN has 1 (812) 359-4965
Old Aug 5, 2017 | 11:28 PM
slour's Avatar
slour
Yes, I believe you are correct
texbigred1
Nov 2, 2016 09:32 PM
Aremee
Apr 2, 2016 10:16 PM
acf6
Feb 16, 2013 05:56 PM
Superdave
Apr 15, 2009 09:35 PM
bigskenney
Sep 3, 2008 11:13 PM
