EBPV Help
Old Dec 13, 2008 | 09:13 PM
robs01f250's Avatar
robs01f250
EBPV Help
Just recently i have noticed that when i drive my truck there is a aweful hissing niose. I know that it is the exhaist backpressure valve but i thought that it was only suppose to work when the truck was warming up. It is doing it all the time. Any ideas?
Old Dec 13, 2008 | 09:27 PM
swaybar's Avatar
swaybar
check the "exhaust back pressure tube" for cracks or holes. i just went through the same thing as you. i took off the tube to try and clean it out and found that where the tube bends and i couldn't see it there was a big crack on the bend of the hose.
new hose=no hissing+better engine running when cold
Izzy351's Avatar
Izzy351
Try tapping on the actuator and see if it's stuck. Is there a noticeable power loss & increase in EGTs?? If so, then you're on the right track...
Old Dec 13, 2008 | 09:29 PM
robs01f250's Avatar
robs01f250
where is the EBPV? and my EGT gauge quit working a little more help needed
robs01f250's Avatar
robs01f250
and what actuator
Old Dec 13, 2008 | 09:40 PM
beanhead6D5's Avatar
beanhead6D5
It's were your exhaust hooks to your turbo there is a flap in the housing that closes to help with warm up,the actuator is under the turbo the lever is hard to see in the valley of the eng.but you can reach down there and give it a tap.
I see if I can find some pics.
Old Dec 13, 2008 | 10:00 PM
beanhead6D5
Ok heres some pics of Joe's turbo and what he did good reading if you have time.go to post #38 and there is the pic your after that is what your turbo mounts to and what works your EBPV.https://www.ford-trucks.com/forums/7...rebuild-3.html
DanielT28
Sep 16, 2012 11:27 PM
willtim1234
Apr 29, 2012 10:39 AM
vicnation
Jan 14, 2007 02:59 PM
bobseng
Electrical Systems/Wiring
Nov 12, 2006 03:55 PM
AaronW
Oct 8, 2001 09:03 PM
