Backfire
Old Oct 8, 2001 | 12:20 PM
AaronW's Avatar
AaronW
Backfire
I am getting a little backfire when I give the truck a lot of gas when its cold outside and the engine is cold. Why is the timing find when the truck is warm and not when it is cold?
Thanks
Aaron
Old Oct 8, 2001 | 01:01 PM
DrFord's Avatar
DrFord
Backfire
instead of timing, it sounds like one of the valves is not seating properly. once the engine warms up the valves expand and it seats better. how many miles are on the engine, might be time for a valve job
Old Oct 8, 2001 | 01:46 PM
73Custom's Avatar
73Custom
Backfire
[font color=red size=2]It could also be the choke, it may need adjusting. I have a manual choke, and if it's not set correctly I get a backfire or a hesitation. Might want to look at the choke...
Marty
"Cleverly Disguised as a Responsible Adult"[/font]
Old Oct 8, 2001 | 04:33 PM
mattd32208's Avatar
mattd32208
Backfire
Old Oct 8, 2001 | 06:27 PM
KONKILR's Avatar
KONKILR
Backfire
I had the same problem with mine, it was a bad exhaust valve. To temporarily hide the problem I eliminated the vacuum advance. I have a 400 and have been told this is typical, especially since a manifold leak caused it.
jake
Old Oct 8, 2001 | 09:03 PM
toyshop's Avatar
toyshop
Backfire
Is backfire out carb or exh. Carb backfire indicates a lean condition, which doesn't surprise me with a cold engine due to poor atomization. exh backfire is usually too rich, or timing, or bad valve. Good luck.
supermandn59
1983 - 2012 Ranger & B-Series
Feb 17, 2011 07:38 AM
F450 Aaron
19
Sep 16, 2006 02:40 PM
slothshady
Aug 16, 2003 03:07 PM
AaronW
Jul 1, 2002 05:26 PM
AaronW
Jun 5, 2001 09:33 AM
