booster blow by
Old Dec 12, 2008 | 05:31 PM
Deluge's Avatar
Deluge
booster blow by
Hi Guys, I've run into a problem. When the truck( pre 99 F-250) is cold there is alot of blow by, sounds like a major air leak. I checked the rubber boot from the turbo to the radiator to no avail. It sounds like its coming from that area. When it acts up I have power reduction, but it seems after it warms up the problem goes away. Someone mentioned a possible waste gate valve problem. I hope that's not the case -$500 fix! Any other suggestions?
Old Dec 12, 2008 | 05:49 PM
Smokin''s Avatar
Smokin'
Smokin
Blowby..what do you mean by blowby?
To be honest it sounds like its just your EBPV activating. Your truck has what is called an EBPV, or exhaust back pressure valve. When its cold outside, it shuts so your truck warms up a bit quicker.
Sounds sorta like a jet engine does it? And when you hit the gas or the brake it stops?
Here is a video of EBPV, just so we can rule that out:
http://www.youtube.com/watch?v=qn94r...eature=related
Your truck is a bit sluggish until it warms up, and that is normal as well. Takes a while to get all those fluids warmed up with such a big motor.
Old Dec 12, 2008 | 05:59 PM
ernesteugene's Avatar
ernesteugene
Well hopefully you've just got a boost pressure leak when under load, and you don't have an actual "blow by" issue because that's a symptom of a more serious problem. Does this "sound" occur when at idle? If it does, then that's possibly due to actual blow by, and you should remove the oil filler cap and see what's coming out of there by holding your hand on it and feeling for any pressure.
Old Dec 12, 2008 | 06:08 PM
Deluge's Avatar
Deluge
Yes it does sound like a jet engine, but only when it gets to about 1300rpm. This is the 1st time having heard this (192K miles) sound. Just started it up (8 degrees out)again and it starts about 1300rpm but goes away when at idle.
ernesteugene
I guess that sound could be caused by a leak in the steel line where it connects to the EBP sensor near the radiator!
Old Dec 12, 2008 | 06:17 PM
250turbo's Avatar
250turbo
welcome to FTE,if you have pre 99 go down to 94.5-97 obs. sounds like ebpv. do you have a wastegate on turbo
kurt
Old Dec 12, 2008 | 06:22 PM
Deluge's Avatar
Deluge
it's a '99 but the 1st model in Sept of '98. It could be the waste valve but listening to Smokin's thread on you tube, it definetly sounds like that
Old Dec 12, 2008 | 06:28 PM
Izzy351's Avatar
Izzy351
it's just your EBPV. Completely normal. first winter with the truck??
Old Dec 12, 2008 | 07:14 PM
Smokin''s Avatar
Smokin'
Smokin
No worries. Just your truck going incognito as Darth Vader...or a leaf blower on crack.
Old Dec 12, 2008 | 07:17 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Hey Gene. good to have you posting. I think it is only the EBPV closing to get the truck warm. I love the jet engine sound.
Old Dec 12, 2008 | 10:40 PM
Deluge's Avatar
Deluge
its not the first winter, I've had the truck since brand new. If at idle it doesn't do it, but if I take it up to 1300 or so rpm it starts to dump. Again, only when its cold but then again that's been alot lately.
Old Dec 13, 2008 | 11:42 AM
Deluge's Avatar
Deluge
So, how hard is it to replace the ebpv? It doesn't do it all the time. Will I wreck anything by not fixing it right away? I took it the local service station and they ran the codes, the only thing came up was the computer module. They don't fix diesels.
Norsegod127
1983 - 2012 Ranger & B-Series
Feb 15, 2015 07:25 AM
Swingshiftworker
Aug 29, 2009 08:53 PM
ccoram
1997 - 2003 F150
Sep 2, 2008 04:57 PM
aquaholic
Feb 17, 2007 08:53 PM
ArcticMotorsports
Oct 27, 2006 03:37 AM
