I bought the whole setup for 40. One question though, on the newr upper intake there is no pcv deal on it. Ill just have to use my original upper which is fine but im wondering where the pcv is on the newer 5.8s
PCV is in the pass valve cover on the trucks, maybe you're talking about something else?
If you're talkin about the fitting where the rubber hose attaches to the intake from the PCV valve(usually at the bottom back of the plenum), then it's a good idea to move the connection point to the vacuum tree anyway. The crank vapors carry some oil and the location of this port is known to cause plug fouling and/or excessive crud buildup in the rear cylinders. I attached a longer piece of hose to the PCV valve and brought it up around the back of the upper to the main vacuum tree. This makes it a little easier to install the upper and spreads the vapors over all cylinders as well.
