Sponsored by: Real Truck
Shock replacement and front end alignment
Old Dec 8, 2008 | 12:06 PM
jamie7375's Avatar
jamie7375
I am replacing the shocks on my 2004 f250. Do I need to get the front end aligned again after i do this. Going to replace them tonight.
Old Dec 8, 2008 | 12:09 PM
monsterbaby's Avatar
monsterbaby
Welcome to FTE first.
IF your only doing shocks they do NOT change the alignment or have any affect on it so NO you don't need to get it aligned.
Old Dec 8, 2008 | 12:11 PM
jamie7375's Avatar
jamie7375
Thanks for teh help. Look forward to getting to know alot more about the fords as i have always owned chevys. Love this truck though..
Old Dec 8, 2008 | 12:39 PM
ReAX's Avatar
ReAX
I agree, it's not a bad idea to have the alignment checked after shocks. However there should be any change to the front end that would require an alignment.
Old Dec 8, 2008 | 12:50 PM
jamie7375's Avatar
jamie7375
Thanks for the help. Ill put them on tonight and let everyone know how it goes.
Old Dec 8, 2008 | 12:56 PM
ReAX's Avatar
ReAX
If your doing Bilstiens, when you get to the rears have a decent phillips screwdriver or awl handy. It's bear to do rears on your own, so I get the top started, compress the shock and as it extends down, I jam the screw driver through the axle mount hole into the shock bushing and out the other side of the mount. This holds the shock in place and lets you wiggle the bolt back in as you pry the shock to line up with the screwdriver.
I can't remember any tricks for the front. I think they were always pretty easy to put in, just difficult to work around the tire.
Old Dec 8, 2008 | 02:02 PM
Citypol86's Avatar
Citypol86
Thanks, I'm going to do this this week hopefully, if the weather co-operates. I tried to give rep points but it wouldn't let me.
Later...
Brewster...
Old Dec 8, 2008 | 02:06 PM
ReAX's Avatar
ReAX
I got them, thanks.
Old Dec 9, 2008 | 08:19 AM
SGnAZ's Avatar
SGnAZ
You are so right about the rears,it took two of us to put those on,didn't think of the screwdriver trickThe fronts were easy,I just took off the wheels and they went in easy.
parkland
Nov 3, 2014 07:40 PM
rpenterics
Sep 9, 2014 10:50 PM
turnkyle
20
Sep 1, 2014 08:28 PM
galusham
Jul 15, 2014 04:35 PM
tim nick
1997 - 2003 F150
Dec 23, 2006 01:26 PM
