Sponsored by: Real Truck
Pulling to the right - oooops
Old Nov 3, 2014 | 05:36 PM
parkland's Avatar
parkland
Truck was driving perfect, got a small 3.5" lift, still drove perfect.
After the truck came back from the lift guy, truck drove perfect, but steering wheel was off center. Because of the lift I assume.
Took it to an alignment place, told them to do an alignment, and adjust the bar so the steering wheel was centered.
Now, the steering wheel is centered, but it pulls slightly to the right.
They said it didn't even need an alignment, and everything looks good, and tight.
Soooo...
If the front end is all tight, and it WAS driving perfect, what do I need to do?
Does the steering link shock absorber need a spacer?
Is the steering shock absorber a culpret? Does it have a spring in that thing, or not?
Only after adjusting the steering wheel position, does it pull to the right, it did not pull at all before.
Old Nov 3, 2014 | 06:05 PM
Tom's Avatar
Tom
The steering damper exerts no spring pressure, it just dampens motion. Sounds to me like your caster is off which is causing your truck to pull with the road crown. Lots of alignment shops have trouble getting the caster right, and if your radius arm brackets weren't lowered where they hit the frame your caster was affected by your lift.
That's where I'd start.
Old Nov 3, 2014 | 06:17 PM
parkland's Avatar
parkland
How then was it 100% fine, until they adjusted the steering?
Seems to me it has to be something in either the tie bar, stabilizer, or steering box ???
Old Nov 3, 2014 | 06:23 PM
Tom's Avatar
Tom
How is your steering gear or stabilizer going to care if the wheels are in alignment? Unless your track bar is adjustable there's nothing they could do to alter it.
Old Nov 3, 2014 | 06:34 PM
parkland's Avatar
parkland
I really don't know. To be clear, they didn't need to change anything on the front end, they said it was perfect, so nothing was adjusted other than whatever they did to adjust the steering wheel position, which I assume would be adjusting the steering link?
Old Nov 3, 2014 | 06:37 PM
parkland's Avatar
parkland
Is there a spring in the steering column to return to center?
Old Nov 3, 2014 | 06:48 PM
Tom's Avatar
Tom
Nope. Proper caster is all that exists to return the steering wheel to center. To straighten the wheel they'd just adjust the drag link at the adjustment sleeve; that's also not going to have anything to do with pulling to the right.
Old Nov 3, 2014 | 07:19 PM
parkland's Avatar
parkland
Awwww crap
So even though they said they didn't have to touch anything, they obviously touched something, and now it's all out of whack ?!
Now what should I do if the alignment shop says it's pulling because of the steering box?
Seems they work on these types of trucks steady, so whatever's wrong must not be a normal issue, or else they are "brain farting".
Old Nov 3, 2014 | 07:22 PM
Tom's Avatar
Tom
The only way that's possible is if the spool valve in the gear has failed. If that's the case it would pull constantly whether or not you're going down the road. To rule this out jack the front end up and start the engine. If the wheel doesn't turn on its own your gear is fine.
Old Nov 3, 2014 | 07:40 PM
parkland's Avatar
parkland
I'm thinking that because this issue was present after picking the truck up, and not before I dropped it off, it's gotta be something they did, and not anything that failed.
Lariatstang
Sep 8, 2018 05:18 PM
oltractor
Mar 12, 2017 01:23 PM
Cluney93
Jan 11, 2010 11:56 AM
the lotty
Apr 17, 2004 09:10 PM
250SDBeast
Jan 2, 2004 10:44 AM
