Sponsored by: Real Truck
Any issues with Hypertech speedometer recalibrator ?
Old Dec 8, 2008 | 10:45 AM
peachboy's Avatar
peachboy
Hi there,
Just installed 37" tires on my newly lifted 2008 F-250
Speedo is obviously off. I checked the Truspeed website and it doesn't seem that the 08 SD is on the list.
Any speedo recalibration info appreciated.
Marc
Old Dec 8, 2008 | 11:22 AM
ReAX's Avatar
ReAX
I can't imagine the 08 uses anything special, it should just be a digital VSS. Superlift may not have had the opportunity to try one on an 08 yet is my bet to why it's not in the app guide yet.
If hypertech is using a specmo style box, it would stand to reason that the truspeed will work as well. If your talking about a tuner, if one has the vss cracked, they all should. Before you spend a couple hundred dollars on one, check in to the tuners. For a bit more money you can get a lot more use out of the tuner.
Old Dec 8, 2008 | 11:32 AM
peachboy's Avatar
peachboy
I'm actually waiting for Banks to release their tuner for the '08 SD, seems they have had issues with the prototype. I was wondering if there was a cheap solution while I wait. Would make a nice complement for the Banks intake and mufflers I just got.
Old Dec 8, 2008 | 12:27 PM
ReAX's Avatar
ReAX
Nothing cheap that I know of, the specmo boxes should be in the $200 bracket.
Old Dec 8, 2008 | 07:20 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
Not cheap.......Merlin Speed Wizard
Speed Wizard Speedometer Correction
Old Dec 9, 2008 | 08:21 AM
kenneBF250V10's Avatar
kenneBF250V10
The Superlift TruSpeed works great. I installed one on my '01 and after a little tweaking, I managed to get my speedo to read exact with my GPS. I'd just give Superlift a call.
Old Dec 9, 2008 | 11:19 PM
XL1200LTD-Keith
The SUPERLIFT TRUSPEED™ SPEED SENSOR RECALIBRATOR is not listed for the 2008, but the Merlin Speed Wizard is. I run the TRUSPEED™ SPEED SENSOR RECALIBRATOR in my 2001 too. I set it up with a gps. It made a difference in correcting the shift points with the 35's.
Superchips makes a unit called the Tirepaq that corrects the speedo too.
Old Dec 9, 2008 | 11:51 PM
ReAX's Avatar
ReAX
Tirepaq is different from the specmo boxes like granatelli's and the truspeed. The tirepaq is a stripped down tuner, for a fee you can have it updated to full tuner.
MARC
Mar 30, 2016 11:59 AM
bass-n-fire
1997 - 2003 F150
Mar 8, 2016 06:04 PM
Ron94150
Aug 29, 2015 09:23 AM
68cabby
2009 - 2014 F150
67
Dec 29, 2014 09:01 AM
MikeyM
Sep 25, 2014 12:24 PM
