Sponsored by: Real Truck
Speedo recalibration
Old Sep 24, 2014 | 09:45 PM
MikeyM's Avatar
MikeyM
Switching from 20 inch wheels to 18 inch on a new Superduty. I know, I know, but I like the looks of 8teens better. So my question is, does that screw with the speedo? Does it need to be recalibrated, or am I overthinking things?
Old Sep 24, 2014 | 10:45 PM
Lattitude Adjuster's Avatar
Lattitude Adjuster
If the diameter of the tires on the new rims is different, yes you will have to change it.
The trans shift points will change also.
On my old truck, I changed the calibration using my tuner.
I am not sure if this is the case with your truck.
LA
Old Sep 25, 2014 | 09:12 AM
snelldawg's Avatar
snelldawg
Dealer can reprogram to a size that is in the Ford system that was available for your model truck. I went from 18's to factory 20's and the wheel diameter is definitely bigger in my case. Will be the opposite for you.
Old Sep 25, 2014 | 11:25 AM
Mcrafty1's Avatar
Mcrafty1
I have an F250 with 17 inch wheels on it now....I have a set of 18inch wheels with traction treads to put on it for the winter for plowing.
Will this be possible on my truck.... 2007 F250 XL Thanks and sorry for the hijack.
Old Sep 25, 2014 | 12:14 PM
Husky44's Avatar
Husky44
Wheel diameter makes no difference with regard to speedo calibration. TIRE diameter makes a difference. If your tire diameter stays roughly the same, you are good.
Best advice is to make the swap, then run your speedo against a GPS to see how much your indicated speed varies from actual. If it's significant, you can either change it with a tuner (expensive option if that's all your going to do), or get the dealership to do it (should only cost you an hour of labor).
If it changes enough to warrant a speedo change, you might consider whether you've affected your final drive ratio enough to need to adjust shift points (assuming you're an auto).
Old Sep 25, 2014 | 12:20 PM
Lattitude Adjuster
When I reset the wheel diameter using the tuner, the shift points adjusted also.
It started shifting as it should.
LA
Old Sep 25, 2014 | 12:24 PM
MikeyM's Avatar
MikeyM
Thanks boys. I have a call into the dealer now. We'll see what the Tech rep says.
gwil12
Apr 24, 2012 07:50 PM
87wreckerman
Nov 17, 2008 04:28 PM
minnesotakim
May 19, 2008 12:23 PM
Squirrel RJ
2004 - 2008 F150
Sep 28, 2004 12:25 PM
03f150man
Oct 30, 2003 08:44 PM
