weird vibration
Old Dec 24, 2008 | 01:47 PM
  #31
99sbm's Avatar
99sbm
found it.
now what is it. lol. its the little ball i was talking about. the piece in picture bolts to the transfer case.
Old Dec 24, 2008 | 02:26 PM
  #32
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Great, that is what I am going to be doing saturday,,,,, nice when ya find the problem!
Old Dec 24, 2008 | 02:56 PM
  #33
chuck101st's Avatar
chuck101st
It's called a double u-joint centering yoke assembly. I just replaced one a couple of months ago. Got it at Parts America but now they don't have a listing on the web site. It seems to me like it was just under $50 for the ball and flange. Have to buy the u-joint seperate. They will probably show a listing for the entire assy. and a repair kit. But when they look it up more than likely they will only have or be able to get the kit. A few years ago I bought one for a 79 F-150 4x4 and got it at a welding shop. I think that they had the entire assembly.
Old Dec 24, 2008 | 03:19 PM
  #34
Pickupmanx2
Or a Cardan joint, CV joint, a few different names
Old Dec 24, 2008 | 05:43 PM
  #35
99sbm's Avatar
99sbm
yea i found it on bronco graveyard and they listed it as "cv head, cv head ball, & spicer spring" but i got a buddy that works at advanced auto parts that knows these truck real well and we were able to find one in town. for the flange, ball, spring and u joint it was just under $60, then with his discount i got it for $43. needless to say truck is fixed and no more vibration.
Old Dec 26, 2008 | 08:03 PM
  #36
Pickupmanx2
OK, so how does the ball come out?!?!? I have mine apart, and a rebuild kit on the way,,,,, or do I have to buy the new flange to get a new ball? Mine is in good cond, smooth moving, should I do it, I am of the mind that when you have it apart, do all you can to it.
Old Dec 27, 2008 | 11:09 AM
  #37
Pickupmanx2
Anyone?!?!
Does the ball come out?!
Old Dec 27, 2008 | 07:37 PM
  #38
99sbm's Avatar
99sbm
um the ball came out of mine when i replaced the first u joint. the new one i got the ball didnt come out, although i didnt try to hard to take it out.
Old Dec 27, 2008 | 11:44 PM
  #39
Pickupmanx2
Mine would not come out, it was still tight, and the needles looked good, so I put all new u-joints, lubed er up real good and put it back on the truck.
Old Dec 29, 2008 | 08:12 PM
  #40
masterbeavis's Avatar
masterbeavis
I am told that rebuilding CVs are a bi aa ee tt ch. I don't bother trying to do it, I just find a shaft with a good CV and run it instead. A driveline shop will install a new one for ya, for alot less headache (but more money) than trying to do it yourself.
Previously mentioned, if your shaft is out of balance, you can try to balance it yourself with a couple of hose clamps. Another trick I have heard is to drill a hole in the driveshaft and add a couple of ounces of ATF, and weld the hole up.
Old Dec 29, 2008 | 08:23 PM
  #41
chuck101st's Avatar
chuck101st
The CV's aren't all that bad until you get to that last cap on the second u-joint. THEN THE FUN BEGINS!!!
Old Dec 29, 2008 | 11:21 PM
  #42
99sbm's Avatar
99sbm
really it wasnt that bad. once i got home with the new parts i had it all back together in 20 minutes.
78_79ford
Apr 28, 2015 10:12 PM
Superduty ROCKS
Feb 27, 2014 02:38 PM
adam83
51
Jan 13, 2014 10:07 PM
pcwb
Sep 18, 2008 11:30 AM
wresleu
1983 - 2012 Ranger & B-Series
Feb 28, 2004 09:17 PM
