pedal vibration?
Old Feb 25, 2004 | 08:25 PM
wresleu's Avatar
wresleu
pedal vibration?
I feel a funny vibration in my gas pedal when driving my 96 Ranger 4x4/3.0. At first I suspected it was time that the bearings need to be repacked, but I certainly wouldnt think I should feel it in the gas pedal only. Could this be something with the throttle body? The whole truck does vibrate, but it's weird how I can feel it on the gas pedal. It baffles me what this could be...and ideas? Could this be a sign of the rear end going bad? Any foolproof ways to tell if the rear end is starting to go? Or could this be a tranny mount or something along those lines?
Old Feb 25, 2004 | 08:33 PM
Nightrain's Avatar
Nightrain
I feel the same thing when driving my dad's 2000 4.0L.I can feel the pedal vibrate at all RPM's and the truck likes to shimmy n' shake at idle ...
Haven't really paid that much attention to it.Doesn't seem like a big deal to me.
Anyone else?
Nightrain
Old Feb 25, 2004 | 08:38 PM
Dealford's Avatar
Dealford
The first thing you have to determine is whether the vibration is speed related or engine related.
Does it steadily increase with ground speed or does it increase and decrease as the tranny upshifts or down shifts?
Old Feb 25, 2004 | 08:54 PM
wresleu's Avatar
wresleu
Well to be honest, it doesnt seem to matter if its upon acceleration or at constant speed. Nor does it matter if its upon the tranny shifting or not. I guess it's weird to explain, but I feel it most at the first half of the acceleration (when the pedal hits about one third the way) is when i start to feel it the most. Honestly it feels like there is a cable sticking or something. The engine seems to run relatively smoot considering the 135,000+ miles shes carrying.
Old Feb 25, 2004 | 09:11 PM
Dealford's Avatar
Dealford
Never overlook the tranny mount. That's one place where many mystery vibrations originate.
Also, when was the tranny service done last?
Old Feb 26, 2004 | 04:18 PM
wresleu's Avatar
wresleu
Can anyone tell me specifically what to look for when checking the tranny mounts?
Old Feb 26, 2004 | 09:17 PM
Dealford's Avatar
Dealford
From under the truck, push up on the tranny tailshaft. While you are doing that, watch the tranny mount at the crossmember. If you've got like an inch of travel upwards, then the mount is on it's way out.
Old Feb 28, 2004 | 04:50 PM
wresleu's Avatar
wresleu
well i crawled under the junker today and tried to budge the tranny to no avail. So I'm guessing that eliminates the tranny mounts as the culprit. Is it possible for the throttle cable to get corroded and be kind of "sticky" upon acceleration? Maybe I should investigate that a bit
Old Feb 28, 2004 | 05:25 PM
hreed's Avatar
hreed
If the throttle cable is sticking, you should be able to feel it when the engine is not running. Try it to see if the throttle feels smooth all the way to the floor. I have doubts that your problem is the cable. If the whole truck vibrates, it sounds more like a u-joint, hangar bearing, or wheel bearing.
Old Feb 28, 2004 | 09:17 PM
rellik74's Avatar
rellik74
98 4x4 4L
Gas Pedal problem, sometimes it has a little sticking at the up posistion when cold
Have same problem can only feel it when wearing sneakers tho
cant feel it thru boots
Kjones22
2009 - 2014 F150
Jun 23, 2015 07:54 PM
86fsbronco
29
May 28, 2015 11:07 AM
Nunez57
Feb 15, 2014 05:55 AM
hawgystyle
Oct 16, 2011 09:21 PM
ford8n47
Nov 12, 2006 06:00 PM
