charging/wiring issues
Old Dec 28, 2008 | 11:11 PM
RangerTuff05's Avatar
RangerTuff05
I'm having problems with my lights and heater pulsing as i go down the road. I thought it could have been a bad ground but when i hooked up the volt gauge it fluctuates between 12 and 18 volts. Is it my voltage regulator or is it a wiring problem?
Old Dec 29, 2008 | 12:10 AM
Alvin in AZ's Avatar
Alvin in AZ
What kind of meter have you got... analog/digital?
What voltage scale are you using?
Where are you hooking it to get those readings?
Were you going down the road when you got those readings?
"Is it my voltage regulator or is it a wiring problem?"
Could be either and/or both. :/
Voltage regulator sounds like a good guess to me tho! :)
Alvin in AZ
Old Dec 29, 2008 | 01:18 AM
fmc400's Avatar
fmc400
MSEE
Check that you have a ground strap between your engine block, and the firewall. This grounds the sheet metal, so the regulator is properly grounded (since it grounds through its mounting flange). To really be detailed, you can disconnect the negative battery cable, then check the resistance (ohms scale on the meter) between the negative battery clamp, and the regulator body. Any resistance in this path will cause a "ground shift" so the voltage "sensed" by the regulator will actuallly be smaller than the true system voltage, and the regulator will not maintain proper voltage. You can also ohm out your regulator-to-alternator harness to make sure the wiring is good.
If all those resistance checks look good, the problem is in the regulator. You can take the regulator to the parts store to have to have it checked on a machine, but it might tell you it's good even if it's not because a lot of times the regulator doesn't fail until it's good and hot from being under the hood.
Old Dec 29, 2008 | 10:50 AM
Alvin in AZ
That high voltage reading has been bothering me and wondering why
the battery hasn't been keeping it in check. :/
Could a loose connection to the battery do that?
Alvin in AZ
Old Dec 29, 2008 | 04:36 PM
RangerTuff05
my gauge is hooked into the fuse box and grounded to the firewall(this may be one issue) but i still can't figure out what is causing the pulsing. I need to get a ground strap on it this weekend from the engine to the firewall and see if that fixes it. My question for you guys is if it is a regulator what year do i have to look for. I don't have the typical regulator with the internal breaker. My regulator has a glass fuse you put on the front of it. When i went to the parts store they couldn't find it. oh and last night it must have surged because it blew 2 new halogen light bulbs. I hate wiring
Old Dec 29, 2008 | 09:55 PM
justiz00's Avatar
justiz00
Do you have an amp gauge in the dash? If so try unplugging the cluster to see if the pulsing stops.
Old Dec 30, 2008 | 01:29 AM
Alvin in AZ
Originally Posted by RangerTuff05
...last night it must have surged because it blew 2 new halogen light bulbs.
I hate wiring.
It's possible this problem could end up burning up more than just a couple
light bulbs, need to get it fixed.
Know anyone that owns a meter? :)
Alvin in AZ
