door alignment problem
Old Dec 7, 2008 | 09:25 PM
Murph2006's Avatar
Murph2006
i was gonna put this in the "front clip alignment" thread to keep from adding another thread, but it seemed off topic since the front clip is a whole other ballgame, and didnt wanna hijack the thread. anyway, i took my old door off, it was lined up good but had a HUGE dent that couldnt be popped out. So i bought a good straight door and put it on. i adjusted the door itself quite a bit and still cant get it lined up. Now even though i didnt move the hinges at all before i put the door on, would i still have to adjust them a little bit to make it work? i am talking about where the bolt to the cab.
Old Dec 7, 2008 | 09:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The body hinge bolts are really the fore-aft adjustment, and tilt
The door bolts are really 4 way. Up-down and in-out. So you have a ton of adjustment there with all those bolts.
Just take your time and make small adjustments. What helps too is to remove the striker bolt so you can open and close the door freely.
Josh
Old Dec 7, 2008 | 11:22 PM
bucks77ford's Avatar
bucks77ford
Yeah, the doors can be a pain sometimes and the littlest movement can throw the doors off.
Old Dec 8, 2008 | 12:42 AM
cipsmithers's Avatar
cipsmithers
Don't forget about the door latch post
Old Dec 8, 2008 | 12:46 AM
1977f150xlt's Avatar
1977f150xlt
tell me about getting them to line up! me and my dad spent a lot of time tweaking the doors on both sides! we bought brand new doors, the metal was really good, we can not get any good panels up here for a dentside, all are rotted out or the good ones are bolted to mint restored trucks so doors on both sides where a must, the previous owner had done a half *** resto in 1997 and did a butcher job on bondo on the doors and panels and used it on rust! so the new doors where the way to go and front fenders and drivers floor pan and cab corners and rear quarter panels!, and the doors where around 150 bucks Canadian, every thing else on the truck is American made, like intake and carb and brakes and what have you, and i have to admit for being offshore they where every bit as thick as the stock 70s panels, and they fit like nos! i am serious! you have to keep a eye out when buying panels, i hate offshore, but these panels where sweet! and i can't speak for all offshore panels, but mine are great! and the fender lines match the doors to a tee! and the whole dentside line looks sweet! straighter than factory! and gaps are perfect! the hinges are a pain to adjust but it can be done, i would suggest 2 guys to adjust panels! one to hold in place and the other to tighten bolts, and after some time it will all come out!
Duzzi
Jan 7, 2016 01:25 PM
VrRotate
Sep 7, 2014 05:38 PM
turnkyle
20
Sep 1, 2014 08:28 PM
jerryst
Jun 14, 2014 03:06 PM
TGoodwin
Jan 7, 2014 03:02 PM
