Alignment off with new front leaf springs
Old 10-18-2015, 03:16 PM
Duzzi's Avatar
Duzzi
Duzzi is offline
I put new 33 inch tires on my truck with a bumper extension to fit.
I put new Bilstein shocks all the way around
I put new front leaf springs Heaviest style they make.
They put Tie Rod Adjuster Sleeves
My old springs were wore out. So I put heavier duty ones up front and I had my truck "aligned.
It didn't get fully aligned. The camber kit was the highest that they could put in and still didn't get it fully aligned.
It has postive camber
Old 10-18-2015, 03:32 PM
sean9049's Avatar
sean9049
sean9049 is offline
Welcome to FTE! i know next to nothing about suspension/steering, but the pros will chime in soon. that is very odd though, Good luck. theres a lot to learn about your truck on this forum, start with the stickies and stick around!
Old 10-18-2015, 05:33 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,180 Likes on 811 Posts
Welcome to FTE
Does your truck have the ifs suspension? I cant tell from the pic but did you make sure they were for your type of suspension? I ask because the f350 springs are a bit softer than the f250 ones making them a bit taller to compensate the additional wheight and height.
Old 10-18-2015, 05:57 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Drive it for a while, I bet things settle in. Mine looked similar after I did mine.
Old 10-18-2015, 07:17 PM
ATS Junior's Avatar
ATS Junior
ATS Junior is online now
SPONSOR
How long have they been on the truck for? I would suggest what 427 Fordman said. Give it a little while and let everything settle.
You really shouldn't have any issues because even though these springs may be heavier then what your truck originally came equipped with from factory they still aren't a Heavy Duty spring. When our customers go with the 43-498HD, which is a three leaf compared to your two leaf (also quite a bit heavier in capacity) they usually don't have any type of alignment issues.
Let us know how it turns out!
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Old 10-18-2015, 08:29 PM
Action4478's Avatar
Action4478
Action4478 is offline
If the alignment was ok before the springs( On a straight axle) the alignment after will be fine . What I found on mine when I but new springs (including helper) I needed to lengthen the track bar. Looks like you need a new alignment shop .The toe is off .
Old 10-19-2015, 08:52 AM
Duzzi's Avatar
Duzzi
Duzzi is offline
Twin I beam setup.
It seems to be getting better as time has gone on. Its been a little over a month. Think these are rated for around 3200ish stock ones I thought were around 2500.
Old 10-19-2015, 11:45 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Drive it a little to see how it settles.
Google "adjustable caster camber sleeves".
Look on your existing sleeves and note any markings and its orientation. The markings denote the amount of degrees of correction the sleeve is providing. The orientation denotes whether the correction is to the castor or camber. Duplicate this and then add a degree of camber to each wheel. Drive the truck a little and look at the wheels again. Repeat until you get the results you want.
Old 01-07-2016, 01:25 PM
FordTruckfan89's Avatar
FordTruckfan89
FordTruckfan89 is offline
I'm about to do the same to my truck, exact same brand spring and part#. these springs are rated for 3486lb. Duzzi, how do you like them so far?
sig1911
01-22-2017 01:22 AM
calialx1
03-15-2011 11:56 PM
ken selvy
05-01-2008 11:59 PM
talock
1999 to 2016 Super Duty
02-20-2004 09:41 AM
mudinford
Offroad & 4x4
04-19-2001 10:31 PM
Quick Reply: Alignment off with new front leaf springs
