Programmer or Gears
Old Dec 7, 2008 | 04:20 PM
jefftb's Avatar
jefftb
Programmer or Gears
Here's a quick question:
Assume I'm running 275/285/65/18's on the truck, which of the following two options would perform better theoretically???:
Stock 3.73:1 rear and Programmer
OR
4.10:1 setup without the Programmer
Yeah, yeah, yeah, I know there's a third option of both but let's not go there just yet.
Me....
Old Dec 7, 2008 | 08:28 PM
N3mo's Avatar
N3mo
I'm more of a Jeep guy, and just use the truck to tow a trailer, but in general, a gear change will keep the engine in the proper power band for the given speed. I don't know about the speed sensor on the Ford yet as I havne't dug into the drive tain, but if there is a tone ring in the differential, then your going to need a programmer anyway.
Old Dec 7, 2008 | 10:32 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
programmer.
you have to regear 2 axles...and that can get real expensive...like $2,000 or so.
a programmer will be $400 and net your 15-30 ponies. custom programming will be roughly $500, but you'll get 30-40 ponies
btw, if you do gears, IMO you should step it up to 4.56 gears. that way you can run bigger tires, and still have the performance.
4.10 are nice, but 4.56 are tire smoking fun
harpman1
Computer Chips & Tuners
Mar 14, 2015 07:52 AM
BROWN DOG KTM
6.4L Power Stroke Diesel
26
Feb 22, 2014 10:09 PM
12engine
Connecticut Chapter
700
Oct 1, 2009 04:56 AM
jimkidd
15
Mar 1, 2006 03:22 PM
