Code problem
Old Dec 7, 2008 | 03:47 AM
waterkneival's Avatar
waterkneival
Code problem
I have an early 1999 ford f-350 7.3 that keeps throwing a code 0475 - I believe I replaced it once before. Any idea were it's located. To make sure If I replaced it. If I did why is it going bad again. How to fix it. Came on when it was cold. Thanks for any help.
Old Dec 7, 2008 | 08:18 AM
DieselCamper01's Avatar
DieselCamper01
I do not have a list of codes. What is this? Maybe we can help locate the part that way.
Old Dec 7, 2008 | 09:59 AM
Pocket's Avatar
Pocket
P0475 is Exhaust Pressure Control Valve Malfunction. This code typically pops up when people unplug the electrical connector on the front of the turbo pedistal, or when they completely delete the EPBV. That connector controls the actuator to the EBPV. If it's unplugged, the EBPV will no longer function, and stays open permanently.
If you have not intentionally disabled the EBPV, or if you have not deleted it, then I would suggest checking under the turbo at the pedistal and see if the wire came loose or unplugged.
Old Dec 7, 2008 | 10:02 AM
rbaker6336's Avatar
rbaker6336
P0475* Exhaust Pres Ctrl Valve Error
Old Dec 7, 2008 | 02:13 PM
clintbonnie's Avatar
clintbonnie
It located just to the left of your heater hose that goes vertical into the water pump. When you replaced it, you also need to clean the steel tubing from the sensor to the exhaust manifold (to the front of the passenger side exhaust manifold). I find it easier just to remove pipe and clean it..
scott the jensen
Modular V8 (4.6L, 5.4L)
Sep 21, 2014 02:11 PM
2005f-150
Mar 27, 2011 06:24 PM
Vinford
Paint & Bodywork
Mar 15, 2007 05:57 PM
loneleader
Jan 25, 2005 06:55 PM
