Carb info 300 Industrial Engine
Old Dec 6, 2008 | 05:39 PM
Dr.Accumulator's Avatar
Dr.Accumulator
Motorcraft Tag on the carb. Its on a 300 I-6 industrial engine / hydraulic pump setup
Carb Tag
C1C20
D7JLA
Looking for an inexpensive replacement that isnt so obscure.. whatever will fit.
Old Dec 7, 2008 | 12:57 PM
BigBlue88's Avatar
BigBlue88
All I can find is people asking the same question you are. You might have luck fitting a Carter YF/YFA carb, the 1BBL carb that was used on the automotive version of this engine. It'll have different vacuum hookups, and the choke will be different, but it may be bolt-on compatible otherwise. Take your carb to an Autozone or similar, ask for the carb for (example: 1976 F-100, 4.9L, manual, 4x2, federal spec, dealer A/C), and see if the mounting flanges match. Some of the Carter YF/YFA rebuilds are junk. A popular approach is to get a 1-2BBL adapter and use a Ford 21xx (2100, 2150, etc.) 2BBL carb, with the 1.08" venturi size. Simple, easy to tune, runs great, etc..
Have you tried some of the basic 1BBL debugging for these engines? Make sure mounting screws are tight & gaskets are OK? What symptoms are you seeing?
Old Dec 7, 2008 | 01:30 PM
Dr.Accumulator
bad float, bad accelerator pump, dirt dobber nests throughout
Old Dec 8, 2008 | 05:32 PM
Dr.Accumulator
BTW- My local hotrod shop tracked down a comparable unit from ABC auto parts for around 150 bucks. This unit will be delivered in a few days and ill post part numbers and any issues
Old Dec 9, 2008 | 12:21 AM
BigBlue88's Avatar
BigBlue88
Yeah, that's a little more than loose screws. NationalCarburetor.com claims to rebuild most industrial 1bbl carbs for $148. Probably doesn't include shipping, but they do good work, and I'll bet they've seen plenty of these industrial Ford carbs before, given how prevalent they are.
Still really interested to know if it's compatible with a standard automotive YF/YFA.
rbtom
Jun 4, 2024 01:16 PM
1965GTFB
Jul 12, 2013 11:24 PM
DPDISXR4Ti
Nov 12, 2012 08:59 AM
Furyus1
Nov 29, 2009 12:59 PM
coolcat3406
Oct 16, 2003 07:43 AM
