Sponsored by: Auxito
engine wont fit?
Old Dec 6, 2008 | 12:49 PM
h20fella's Avatar
h20fella
engine wont fit?
i blew a 4.6l in a 98 f150, 4x4 auto transmission, tried to replace it with a 97 f150, which came with a manual transmission, and the mechanic said the new motor will not fit due to the crank, and the flywheel, is this possible, or can they not be retrofitted? they are both windsor motors, i thought any ford motor can replace a ford motor
Old Dec 6, 2008 | 03:38 PM
greenbuckfifty's Avatar
greenbuckfifty
the engine should be able to fit. that should just be as easy as dropping it in and swapping out the transmissions and any additional hardware that may be required.
Old Dec 6, 2008 | 04:58 PM
Bear River's Avatar
Bear River
Former ******
Also, the 4.6L is not a Windsor motor. A '97 F-150 should have the same engine options as your '98. This is not true of '96 however.
Old Dec 6, 2008 | 07:48 PM
Club Wagon's Avatar
Club Wagon
Soon after I got my '98 F150 4X4 automatic w/4.6 L, the experts schooled me on how to tell if the motor is a Windsor or a Romeo. Apparently chains like AutoZone are cued to ask for VIN to resolve this Q, even to replace the serpentine belt!
Since h20fella posted "blew a 4.6l in a 98 f150, 4x4 auto transmission" I'd presume he has the same odds of having either Windsor or Romeo. However all the 4.6L '97 & '98 motors should physically "fit". If "they are both windsor motors" I'd expect most of the connectors to also "fit".
Old Dec 6, 2008 | 09:54 PM
LxMan1's Avatar
LxMan1
The Romeo engine had a 6 bolt flywheel and the Windsor had 8 bolts.
Old Dec 6, 2008 | 10:37 PM
Club Wagon's Avatar
Club Wagon
Counting flywheel bolts can be kind of a hard way to make the distinction between Romeo & Windsor. Many can tell instantly just by looking at the cam covers, which have different bolt patterns. For my work they also had different harmonic balancers.
Looking at VIN numbers can be much easier. If there's a W at a certain position in the VIN it means a Romeo motor oddly enough. Sorry I forget which position & have 2 W's in my VIN.
Old Dec 6, 2008 | 11:27 PM
Silver Streak's Avatar
Silver Streak
The 8th digit of the vin is the engine code on domestic vehicles.
Old Dec 9, 2008 | 04:58 AM
h20fella's Avatar
h20fella
thanks for all the replies, much appreciated
Outlaw Inc.
Nov 2, 2013 06:28 PM
ybnrml22
Mar 31, 2011 07:49 PM
hopper84
Feb 10, 2010 09:07 PM
banky
Sep 11, 2003 05:44 PM
crazy4Fords
Nov 4, 2002 09:30 PM
