ok i wont to do that to my 78 ford f-350 i know how to do it all but 1 thang and would like to know how to do it and thats puttin the lights in 4 the blinkers and the high beam lights the blue light lol and if some one could i would like to watch a video on how 2 do it
Reason: add stuf
This thread is 3 years old and you don't know how to use punctuation.
I think you are asking how to replace the turn indicator bulbs and the high beam indicator bulb, correct?
If that is what you are asking you need to take the trim off the front of the dash, I think there are 3 screws along the top.
You will also need to remove your wiper and headlight ****, search on here and you can find out how to take them off.
Remove the ***** off the radio and I think there are some nuts that need to removed as well.
Once you have the trim off you need to remove the four screws holding the gauge cluster in. Once they are out try to pull the cluster towards you, if you are lucky you will get enough movement to get to the back of the cluster. If not you will need to remove the speedo cable. Do a search on here to see how it is done, it can be a bit tricky.
Remove the bulbs and replace them. If a new bulb still won't work then it will be the printed circuit. That is a whole new subject.
Just a quick question, what did you edit?
Edit:
Sorry, I see now that you know how to do it all so ignore what I just posted.
