289 problems advice needed...
Old Dec 5, 2008 | 07:48 AM
MBDiagMan's Avatar
MBDiagMan
Yes, preignition is certainly a possiblity. That's why I need to hear and maybe drive the car. In these days of knock sensors and EFI, there are probably lots of young people who have never heard preignition before, thus they don't recognize it for what it is.
Old Dec 5, 2008 | 01:23 PM
85e150's Avatar
85e150
On the trail of pre-ignition.
First, what is the timing set to? Should be between 6 & 12, the stock specs for 2bbl or 4bbl.
Now, if you have the casting numbers off the old heads and the new heads, we might be able to see what the combustion chamber volume is. It is possible you have gone from a 54.5 cc to a 53.5 cc chamber.
Those pistons have valve reliefs in them, so that might compensate. Does the piston info say the volume of the reliefs? The old pistons, were they dished or flat?
Head gasket thickness?
You might have 3 little things adding up here. Even if they did, it doesn't seem like it would cause this level of trouble, but all things need to be examined methinks.
Plug in those numbers here:
CUBIC INCH CALCULATOR and COMPRESSION RATIO
Old Dec 10, 2008 | 04:35 PM
gearhed1971's Avatar
gearhed1971
Out of curiosity,how did everything fare?I have one 289 head and one 302 head on an engine I've just bought,It'd be good to know what I'm in for.
Old Dec 10, 2008 | 05:48 PM
85e150's Avatar
85e150
If they are the same style rocker and valve size, no big deal. But I bet they are not. You should match them.
And yes, I'd like to hear more about the tale of the 289 here.
Old Dec 10, 2008 | 08:37 PM
Beanscoot's Avatar
Beanscoot
"I have one 289 head and one 302 head on an engine I've just bought, It'd be good to know what I'm in for."
Well if you provide us with casting numbers then we can determine valve size, combustion chamber size etc. and advise you what you are in for.
Old Dec 11, 2008 | 12:59 PM
85e150's Avatar
85e150
Thanks for pointing that out--But if I'm reading this chart correctly:
Cylinder-Head Casting Numbers
And if it's correct, he is probably mismatched for both combustion chamber size and intake valve size. One side of the engine run better than the other?
Old Dec 11, 2008 | 05:33 PM
gearhed1971
Yeah,I've already checked that,but haven't miced the valves yet.Hpoefully some one machined it to match.But yes,according to the numbers,they're a mismatch.
Old Dec 11, 2008 | 06:01 PM
gearhed1971
they are both c8oe heads,but where is the suffix?All I see is C8OE,no dash anything.
craigibc
Jan 26, 2022 08:40 PM
craigibc
Mar 7, 2010 03:12 PM
craigibc
Feb 5, 2010 06:50 AM
restoringmy46
Oct 4, 2006 09:23 AM
imlowr2
Aug 14, 2004 07:23 PM
