Yes, preignition is certainly a possiblity. That's why I need to hear and maybe drive the car. In these days of knock sensors and EFI, there are probably lots of young people who have never heard preignition before, thus they don't recognize it for what it is.
First, what is the timing set to? Should be between 6 & 12, the stock specs for 2bbl or 4bbl.
Now, if you have the casting numbers off the old heads and the new heads, we might be able to see what the combustion chamber volume is. It is possible you have gone from a 54.5 cc to a 53.5 cc chamber.
Those pistons have valve reliefs in them, so that might compensate. Does the piston info say the volume of the reliefs? The old pistons, were they dished or flat?
Head gasket thickness?
You might have 3 little things adding up here. Even if they did, it doesn't seem like it would cause this level of trouble, but all things need to be examined methinks.
And if it's correct, he is probably mismatched for both combustion chamber size and intake valve size. One side of the engine run better than the other?
Yeah,I've already checked that,but haven't miced the valves yet.Hpoefully some one machined it to match.But yes,according to the numbers,they're a mismatch.
