General Automotive Discussion
Help Quick
Old Dec 4, 2008 | 08:45 AM
Dustin_86's Avatar
Dustin_86
Angry Help Quick
My 99 auto zx2 ford escort has developed a bad hum from the drivers side from wheel area. I can not hear it with the window down, just from inside the car. It starts around 30mph and continues the noise up to exactly 60mph. if I slow down it will carry the noise to about 20mph or so. It does not change with the wheels turned"cornering". It does not make the sound above 60mph. Puting the trans in Neutral at 30-60mph made no diffrence. Shops want $75 to "diagnose" and the shops here in Waco look shady. I'm a college student on an extreme budget.Everyone says "wheelbearing" until the ride with me and the noise goes abway at 60mph. Maybe a CV axle, but it does not "click" when turning and grabbing the cv axle is a little play 1/8" but not much. The cv boot is not torn eather.
Help Please
Dustin
PS Stuck in waco, with no reputable people to help me fix it,in an apt complex, with college finals next week and worried that my car is going to cratter
Old Dec 4, 2008 | 12:33 PM
Lazy K's Avatar
Lazy K
Don`t know but if it was me I think I would swap the left front wheel with the rear to see if the noise changes.
Old Dec 4, 2008 | 12:48 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
While you have the wheel in the air, see if the front wheel bearing is tired.
Stand facing the lug nuts. Grab the tire at the 12 and 6 O-clock postion. Gently try to twist the tire toward and away from you. Do you feel any play?
If you feel play, look to see if the movement is only at the axle or if the movement is also in the ball joint area. Only at the axle might be the wheel bearing.
If you don't feel any play, do the tire swap as previously suggested and take the car for a spin.
Keep us posted!
Old Dec 4, 2008 | 07:54 PM
Dustin_86's Avatar
Dustin_86
I rotated the tires a week ago with no luck, What is strange is that in cold 30* tx weather it seems to quiet down some.
Old Dec 4, 2008 | 08:42 PM
wendell borror's Avatar
wendell borror
The most common problem on front wheel drive cars is a wheel bearing or CV, so your on the right trac. Useally when one side goes, the other isn't far behind.
Old Dec 4, 2008 | 11:35 PM
Dustin_86's Avatar
Dustin_86
It wouln't be a wheel bearing if the noise quit above 60mph right? So A CV axlen must be it
Old Dec 5, 2008 | 06:51 PM
monckywrench's Avatar
monckywrench
If I do a CV axle on any of my personal vehicles, it gets a wheel bearing at the same time since it's little extra work. The parts should total about 120 bucks-ish.
If the front wheel bearing and axle "feel" tight I'd consider driving it (gently) until after your finals are finished next week.
Avid_Stroker
15
Jan 23, 2015 07:36 PM
shadetree1980
Feb 17, 2013 02:07 PM
Javi1
6.7L Power Stroke Diesel
Nov 11, 2012 07:52 AM
dongc1
Jan 25, 2008 07:20 AM
Layne
Texas Chapter
Jun 24, 2005 03:21 AM
